hi guys, im selling a Quaife QDF 14K ATB Limited slip differential, converted to chain-drive, including Jack Knight pot joint output shafts and a 530/48T sprocket.
I will enclose a cd with the quaife with instructions for the fitment to standard bike engined minis (or indeed any car). This is a simple conversion lsd for the mini as it will maintain the original positioning of the output pot joints, allowing the use of the standard subframe (or replicated mounting points incorporated into a frame) if wanted.
The differential has been supplied by Westgate Garages only 2 months ago, never used, originally cost me £1250.00 so I'm loosing money on this. Beautifully machined. With Jack Knight output shafts which are very strong, ideal for race applications, and the fitment of the more muscular bike engines (turbo'd hayabusa was my personal plan). I will supply 4 lengths of 3/8" UNF rod which can be used to bolt the bearing carriers to your chassis. A change in jobs etc has left me needing to clear as much of my stuff as possible, this is the only reason for the sale.
Any questions please ask away - 07897404114.
The item is located in LICHFIELD/Tamworth.
£750 ovno
Quaife Lsd Differential Chain Drive, Mini Zcars
rusky
, Jul 21 2009 07:17 AM
3 replies to this topic
Posted 21 July 2009 - 07:17 AM
Posted 21 July 2009 - 05:59 PM
I'll give you £700 for it. Can send a courier to collect
Posted 21 July 2009 - 07:44 PM
I'd let you have it for 700 cash, but wouldnt drop any further. give me a bell on 07897404114 if you really do want it. cheer,s russ
And, yes I can arrange a courier. Where are you based?
Posted 21 July 2009 - 11:03 PM
yeah, thats fine. Do you want my paypal address or do you want me to talk to you first - just to prove this is genuine? If you forward me your address I will get the parcel ready. I would ask that you cover shipping it out - but that should only be 15 quid. russ
