Timing Query
Posted 23 July 2009 - 12:20 PM
Metro 1275 engine, Stage 1 Kit, electronic ignition, 65DM4 distributor.
Hello, can anyone tell me what the correct timing figures should be for this engine with the stage 1 kit? The Mini Haynes doesnt tell me as standard for this type of engine.
I have timed it by ear, that is to say I have set the idle at 2000rpm, turned the dizzy until the revs stop rising, then backed the dizzy off by about 250rpm.
I have returned the idle speed back down to 900 and my timing is at about 14 degrees with or without the vacuum advance attached. And around 20-22 i.e. off the scale at 2000rpm
Any help would be great.
Posted 23 July 2009 - 06:35 PM
at idle, the timing should be more advanced when the vac pipe is attached... as the vacuum at idle pulls on the vac advance... if this isnt happening then i would imagine your vac advance isnt working...with or without the vacuum advance attached
Could be a little too high... but try it... hear for any 'pinking' from the engine when driving it under load...my timing is at about 14 degrees
Another way is to time it at about 32degs @3500 rpm (with vac disconnected) - will need a decent timing light to do that...
hth,
Dave
Posted 23 July 2009 - 08:58 PM
What could be done to confirm that the vac advance isnt working?
As for timing it at 32 degrees at 3500rpm. firstly, where did you get that figure from?
thanks
Posted 23 July 2009 - 09:05 PM
Do you know what 1275 Metro engine it is? That nice Mr Guessworks has an engine number looker upper on his website, I can look in my Metro Haynes if you know.
Posted 23 July 2009 - 09:07 PM
Its a starting point then you run it under load and check for pinking if this occurs then back off a couple of degrees at a time till the pinking stops. Which is pretty much were 32 degrees comes in allowing for modern unleaded fuels .
Posted 23 July 2009 - 09:20 PM
Vac advance shouldn't kick in at idle, open the throttle a bit and you should notice a difference - or just suck on the pipe
I'm not so sure thats true, We had this in a recent topic, I checked two carbs in my garage at the time and the vacuum port is on the manifold side of the buttlerfly valve, it isn't blocked when the valve is fully shut. Now to me with that valve shut is when you will be getting a fair bit of vacuum created.
Also why would you even bother disconnecting the vacuum pipe when setting timing if it had no effect.
Most timing figures specify a certain degree @ 800 - 1500 rpm depending on dizzy. Now tickover is around 900 - 1000
Also as a test with my timing set to 6 degrees @ 1000 rpm if I connect the vac this changes to 18 - 20 degrees.
Posted 23 July 2009 - 09:59 PM
Posted 23 July 2009 - 10:34 PM
There is always some air going past the throttle disc or the engine would stall, that'll be mostly at the top and bottom edges so the fact the hole isn't physically upstream of the disc doesn't mean it isn't upstream of the effects of manifold vacuum. The critical thing will be when it does get exposed to reduced pressure. Removing the vac pipe will ensure there's no advance, not all engines can be assumed to be set up correctly.
I note there's a hole in your throttle disc is that in place of a poppet valve? It could be that allows the throttle to be more shut at idle and is creating more depression over the vac take off hole.
Posted 23 July 2009 - 10:50 PM
When I remove the vacuum there is no notable change in the reading off the timing markers. Certainly nothing anywhere near going from 6 - 18
Are you pulling the end of the vaccum pipe off the dizzy or off the carb? Are you blocking any of the resulting orrifices i.e. the hole on the carb, or the dizzy, or the pipe itself.
The engine number is going to be tricky because some kind soul has rivetted a 99H Plate onto my block, if theres another way of getting the number, i'd be pleased to learn it.
Are we in agreement that sucking the vac pipe will prove whether vac advance is working? If so, what should the other end of the pipe be connected to. (I assume carb)
Posted 24 July 2009 - 07:46 AM
the vac advance on the dizzys do operate at different vacuums, some need more than others before they kick in.
Posted 24 July 2009 - 09:56 AM
I reconnected the end to the carb and disconnected the dizzy end and put my tongue on it and can feel myself being sucked into the carb, so vacuums working that end.
Should be all okay I guess.
Does anybody have any clues regarding discovering the true engine number?
Posted 24 July 2009 - 11:05 AM
The above works all well and good when you at full throttle and flat out, but and there always a but
Posted 24 July 2009 - 11:23 AM
Something I'm curious about, if the max mechanical advance for peak performance on an A series is somewhere around 34 degrees @ 4000 rpm give or take.
If the vacuum is connected and you are say cruising at say 3500 - 4000 rpm, would the vac not over advance it.
I know if I watch my vacuum gauge it can settle to around 10 - 15" of vacuum when cruising.
I know some people who have had rolling road sessions have come away with the vac advance disconnected and just wondered if this was why ??
Posted 24 July 2009 - 11:58 AM
At 3500-4000 rpms the bob weights in the dizzy have taken over control of the engines advance and are usually against the stop pin. Meaning no further advance can take place.
Rolling road operators, usually disconnect the vacuum, because it's either leaking causing all sorts of other problems or there not concerned about economy. But mainly because it's easier !
