years ago i seam to remember it being quite common practice to convert a left hand petrol tank to fit in the right hand side.
can anyone remember how this was done
i dont want an external petrol tank neck as i want to refuel from inside the boot (have closed the origional fuel tank neck hole and smoothed over)
but would still love twin tanks for long distance journeys
had a quick search around in here but cant find anyone doing it
thanks all
Converting A Lh Petrol Tank To A Rh Petol Tank
mini.cooper998
, Jul 25 2009 10:41 AM
8 replies to this topic
Posted 25 July 2009 - 10:41 AM
Posted 25 July 2009 - 12:56 PM
i did this in my mini.. well.. i helped my brother do it.. we took a left hander 5.5 gallon one and cut the lip off the front (nearest the bootlid on a left hand tank and had it seam welded and pressure tested.. then you just have to move the filler neck round to the new possition and weld up the old hole with the piece youve just cut out. then we used a 7.5 gallon tank strap that we modded to go round it as it tucked further back at the top and used the nut that was welded to the rear of the seat.
on mine tho i wanted the twin lok so i cut the whole in the car body witht he measuremnts from the other side... then u can mark the tank when pushed in for the new filler neck.
Posted 25 July 2009 - 02:42 PM
sweet you made it look so easy
very tidy car too out with the grinder it is tonight
Posted 26 July 2009 - 02:20 PM
That thing you have on your wheel is very neat. Did you buy that or make that?
Posted 26 July 2009 - 05:14 PM
made it mate. bit of cheaure plate powdercoated black . chrome wheel brace of eaby for 8 quid bit of old school door rubber round the edge and some chrome clips from b &q. i can make you one if you like haha
Posted 26 July 2009 - 05:22 PM
i want to do this!!!!!!!!!!!!!!!
Posted 26 July 2009 - 05:24 PM
do it then yeti!.lol its really not that hard.. hardest bit is gettin it to sit right round the wheel arch... as its the opposite to the other side.. oh.. and if you weld the tank yourself... leave it full of water for a couple of days first before you weld it as i cannot be held responsible for big booms hahahahaha
Posted 26 July 2009 - 05:28 PM
it on the list of things to do lol along with getting it road worthy which envolves taking the engine out as one of the tower subframe mounts and been stripped so need to re cut it and then get it through mot
although i could do the petrol tank at the same time hmmmmm just need a nother tank lol
Posted 26 July 2009 - 05:35 PM
Teabay my friend! or autojumbles.. u can pick um up for a fiver
