Idiot Question.. Best Grease For Steering Boots?
11 replies to this topic
#1 coyttl
coyttl
  • 243 posts
Posted 27 July 2009 - 06:02 PM
Hey all.. for the later SPis (if it matters) - what is the best grease that should be used in the ball joints on the steering rack? If any? My boot has disintegrated on the left, got two new ones and thought I'd check before going out and getting anything.
Cheers!
Mike.
#2 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 27 July 2009 - 06:04 PM
The ball joints are on the hubs and lithium grease is fine for these. But you mention ball joints on the steering rack?
Do you mean track rod ends?.... if so - these are sealed and cannot be greased... once they die, they're dead...
#3 coyttl
coyttl
  • 243 posts
Posted 27 July 2009 - 06:19 PM
Okay, so i don't know what I'm talking about. :) Big surprise. My CV (ball-joints?) were leaking, so I ordered new ones. While I was under there, there's one on each side connected to the steering rack - these things - which I ordered as well. The one on the left was in veral pieces and they just fell off when I touched them. inside is what looked like a ball-joint, that connected the arm down to the hub.
If this is the track-rod, then good to know, I learnt somethin'. If I can't use them then no fear. I'd like to keep those joints protected, tho. Does that mean they just aren't filled with grease?
Cheers!
Mike.
#4 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 27 July 2009 - 06:21 PM
Thats not a track rod end,
and for the type of grease im not sure, I think the early ones used a type of oil??
#5 Ethel
  • 26,029 posts
Posted 27 July 2009 - 06:27 PM
BP energrease fgl is what it says in the book. They rarely need lubing but if it has picked up dirt I don't see why a general purpose lithium grease wouldn't do, it'll have less to do than a ball joint.
#6 coyttl
coyttl
  • 243 posts
Posted 27 July 2009 - 07:17 PM
Cool, thanks guys!
I ran over to my tire shop and did a quick talking to them, they said that years ago they would use oil, but now they use the same grease that is used for CV joints and the like. Good to know!
Cheers,
Mike.
#7 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 27 July 2009 - 07:26 PM
I just used some general purpose lithium grease when I did the ones on my battered old Renault 19.
#8 stormintrooper
stormintrooper
  • 2,072 posts
Posted 27 July 2009 - 07:43 PM
do you have to fill up the boots with grease or oil or whatever you use?
or just smother the joint with plenty on?
#9 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 27 July 2009 - 07:47 PM
Just completely smother the joint, don't fill the boot up, it's messy and wastes grease.
#10 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 27 July 2009 - 07:49 PM
when i did the steering gaitors i covered the rack and pinion in copper grease and then some lithium grease for inside the gaitor :)
#11 coyttl
coyttl
  • 243 posts
Posted 27 July 2009 - 09:03 PM
Those boots are huge - so I don't think you would want to completely fill them up. When I go to put mine on (should be fun, never done anything like this before) I'm just going to cover the joints rather well and then put the boot on.
Mike.
#12 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
Posted 27 July 2009 - 09:37 PM
that is probs the best option i didnt put too much as i was worried the grease would just OOOZEE out lol
