Fuel Pressure Regulator
3 replies to this topic
#1 Pooky
Pooky
  • 5,691 posts
Posted 28 July 2009 - 09:40 AM
Going to fit a fuel pressure regulator soon to try and combat high fuel consumption/high fuel pressure (I think the Facet pump I bought is slightly too powerful). I'm not sure if the regulator should go close to the carbs or close to the tank/pump. If close to the carbs, before or after the filter? :D
Thanks! :thumbsup:
#2 Mr Joshua
Mr Joshua
  • 378 posts
  • Local Club: Rebels mini club
Posted 28 July 2009 - 10:10 AM
Close to the carb and you need a 6" run of straight pipe uto it.
#3 Ethel
  • 26,078 posts
Posted 28 July 2009 - 10:48 AM
After the filter - there are Malpassi filter kings that do both jobs - used to be standard kit on Alfas, but they're probably even rarer in scrappers than Minis now.
#4 Pooky
Pooky
  • 5,691 posts
Posted 28 July 2009 - 03:15 PM
I have seen the Filterking products but as I already had a filter I couldn't justify spending twice as much on a product that would do the same job.
So that's after the filter, with a 6" run of pipe into it. Any reason for this? What about after the regulator?
