Seething.... :xxx:
29 replies to this topic
#1 tris
tris
  • 17 posts
Posted 28 July 2009 - 06:03 PM
After purchasing my wifes mini and having an interesting drive back from wales to scotland. (the radiater kept overheating)
I book the mini into a mechanic to get it looked at. Luckily enough the mechanic is a friend so checked it over for free.
As I thought, the head gasket is buggered, not so bad, I can handle that, the mini was a good price.
Then he went into more detail.
Considering I bought the mini with a full 12 months worth of MOT (just completed a week or two before I bought it) I was surprised to learn that the rear sub frame was corroded. (essentially causing anything between £800-£1200 total repair cost)
Was was more annoying was that the mini had yellow chalk indicating where the corrosion was.
Basically it looks like the car was failed at one MOT centre and then passed at another.
The gasket I could have lived with, but this is taking the p!$$!!!
I was told by the mechanic to give the garage that did the MOT a courtesy call to find out why this happened, but I'm tempted to go straight to VOSA or DVLA to report them.
What do you peeps think?
*sits back and stews*
#2 1987_ParkLane
1987_ParkLane
  • 2,671 posts
  • Local Club: The Mini Forum
Posted 28 July 2009 - 06:08 PM
How does a rear subframe cost £800-£1200 to repair, you can get a new one for like £250.
On the other hand it is bad that it has been passed in that state and something should be said to the garage, previous owner, etc.
#3 Ethel
  • 26,074 posts
Posted 28 July 2009 - 06:09 PM
Did you buy it from the garage?
I'd contact the seller first, it's leverage to get it sorted. If you've already reported them they have nothing to gain and every reason to try 'n wriggle off the hook.
Might just have been an advisory, rightly or wrongly. You could get it fixed for much less than that.
#4 tris
tris
  • 17 posts
Posted 28 July 2009 - 06:10 PM
Because apparently that wasn't the only problem. Plus I'd have to pay for labour (as I'm not a grease monkey...... yet)
#5 Pooky
Pooky
  • 5,691 posts
Agreed, you could find a second hand one in decent nick for £100 and spend a weekend changing it yourself :P
#6 tris
tris
  • 17 posts
Posted 28 July 2009 - 06:11 PM
The MOT had no advisories on it >:P )
#7 somecrapname
somecrapname
  • 371 posts
Posted 28 July 2009 - 07:06 PM
i just got a second hand one in good condition for £60, radius arm repair set at £30 for the pair, drum overhaul for <£20, cones aren't too expensive either if you stick with standard stuff! and the work isn't that hard to do, 2 or 3 spanner rating in haynes?
on the other hand.... why didn't you check the subby to see what condition it was in? poke it with a screwdriver and you'll soon find any rust!
#8 DaveRob
DaveRob
  • 703 posts
Posted 28 July 2009 - 07:36 PM
That is untill the subframe mount bolts shear....... which is THE most common scenario...... if they come out easy... 2-3 spanners...... if one shears.... well... bit of ingenuity required.
Rob.
#9 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 28 July 2009 - 07:38 PM
and the moral of this story is... NEVER buy a mini without LOOKING at all the usual rust spots.
don't trust the MOT, look for yourself :P
#10 mattwho?
mattwho?
  • 844 posts
Posted 28 July 2009 - 08:13 PM
do a mot chek and see what it faild on first time
#11 mattwho?
mattwho?
  • 844 posts
Posted 28 July 2009 - 08:14 PM
http://www.motinfo.g...ECHIDDispatcher
#12 JoneseyBoy
JoneseyBoy
  • 808 posts
i would personaly call the mot station and bribe them to put it right or you will get there licence taken of of them either way you dont lose out just get sum satisfaction either way but one way youll have to pay a bit
#13 robtheplod
robtheplod
  • 960 posts
Posted 28 July 2009 - 08:16 PM
After my experience I would say that an MOT means absolutely nothing. My mini had an MOT a week prior to me buying it and was SORN a month later due to the dangerous problems..... :P
#14 Burnard
Burnard
  • 3,350 posts
AHMEN to that!
I cant belive mine had an mot with so many holes in the sills.
If you use plenty of penatrating oil (3 in 1 penatrating oil works VERY well) the bolts should come out reasonably easy. Its worked very well so far for me.
Chris
#15 rick.spi
rick.spi
  • 1,686 posts
  • Local Club: "WOT NO BRAKES"
Posted 28 July 2009 - 08:22 PM
i wouldnt alert the dvla/ vosa as thats a bit petty, but i would ring the past owner and garage and see what the score is, if worst comes to worst you could bribe them but... reporting is a bit far, thats only my view
best of luck and hope you get the car sorted :P
