Which Oil Filter?
Posted 28 July 2009 - 08:05 PM
But anyway, can anyone tell me what oil filter I need for a Metro 1275 engine? Is there just one type of filter on engines after 1974 as the Haynes manual says? An engine swap was done some time ago and I don't know what year it is or even if it's an MG.
And I know not to buy one for a K-series!
Posted 28 July 2009 - 08:11 PM
Other wise you've got an early A series with a paper filter in a metal case or a Late MPi with a filter that screws directly into the block...
Edited by Pooky, 28 July 2009 - 08:12 PM.
Posted 28 July 2009 - 08:31 PM
As long as it's an A or A+ series with a spin-on filter THIS should be the one you'll need if it is a Metro unit. Otherwise it's probably THIS one
Well it's not a paper type and it's not an MPI either. I'm also pretty sure that all Metros are A+ which narrows it down a bit. Would the best way be to take the filter off and look at the pattern of the holes on the inside, or do I need to drain the oil first?
Posted 28 July 2009 - 08:43 PM
Posted 28 July 2009 - 08:53 PM
Posted 28 July 2009 - 08:55 PM
Minispares are doing an offer with oil and filter at the mo
worked out great value!
well in that case.... what he said
Posted 29 July 2009 - 02:53 PM
Don't know if you all have FRAM in the UK but in NA they are a pretty substantial company but do not list a number for a mini.
Would be good to know incase I need to stock up on filters.
Nasty
Posted 29 July 2009 - 02:59 PM
Hate to almost JACK a thread, but anyone know the "FRAM" filter number for a MINI 1000?
Nasty
I use the 3614 on mine.
