Gunson Tools
4 replies to this topic
#1 Minion Burn
Minion Burn
  • 153 posts
  • Local Club: Bergen mini owners
Posted 29 July 2009 - 11:23 AM
Been looking at a couple of Gunson tools and was wondering if anyone has experience with them.
The two I am looking at are the Gunson - Trakrite Wheel Alignment Gauge and the Carb Balancer.
#2 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 29 July 2009 - 11:26 AM
Ive got the carb balancer and the colourtune.
Carb balancer isnt brilliant, helps a little, but I found it not that great over all.
#3 lrostoke
lrostoke
  • 6,923 posts
Posted 29 July 2009 - 11:31 AM
I've got the trakrite brought it new of ebay seemed best price.
It was easy to use but can't vouch for how good it actually sets the tracking, can only say that I don't appear to have any uneven tyre wear and it steers and corners ok.
carb balancer not to bad, gives a visual indication of low through each carb, but best to check a few times we found reading could vary depending how you had it sitting on the intake.
#4 andyapanel
andyapanel
  • 625 posts
Posted 29 July 2009 - 12:24 PM
I used to use the Carbalancer on a 1500 Allegro. It worked like a treat. However, the carbs needed FREQUENT rebalancing,so Ime a single carb man, now. However, its the tool you need-I would recommend it.
#5 CraigyBoy
CraigyBoy
  • 407 posts
Posted 29 July 2009 - 12:42 PM
I have a Gunson Easi-Bleed and it worked fine the first few times I used it, after about 5-6 times though seals started leaking and the other day i came to bleed the clutch and the top cap has split. Not happy with it really.
