B-series Traverse?
Posted 29 July 2009 - 02:52 PM
Obviously would need the gearbox off a traverse engine if i wanted to keep it fwd (which i do)
Any ideas/problems etc?
Posted 29 July 2009 - 03:32 PM
Posted 29 July 2009 - 03:44 PM
i think the problem would be the width of the engine and side mounted gear box fitting under the bonnet
Side mounted transverse gearbox?
Isn't the 'B' Series engine a, f*cking heavy & big chunk of iron with no real power? Like 1800cc & 95HP? If it's only for the sake of doing something different - why not. Probably suits a 'Princess'/O-Series gearbox. Resp. can be made to fit. With all the work needed for another egngine conversion - with less power. If it's not too big at all?
Posted 05 August 2009 - 08:37 PM
It was heavy and I think the steering was seriously restricted but it went well enough in a straight line and the guy that built it was happy enough
lo tech by todays standard but there you go.
Posted 05 August 2009 - 10:32 PM
they are quite a bit taller the the mini engine.
Posted 16 September 2009 - 02:42 PM
1750 yes B series no, it was an O series if i remember correctly.If I am correct the Austin Maxi was a 1750cc b series engine,
Posted 16 September 2009 - 03:49 PM
"several people who were working for BMC at the time have gone on record as saying at least one Mini was specially prepared for the film, being equipped with the BMC 1800cc B-series engine and gearbox from the BMC 1800 'Landcrab', as the Coopers lacked sufficient torque to climb stairs."
thats a quote of this website http://www.theitalia...ars_coopers.htm.
Posted 17 September 2009 - 06:44 PM
Posted 17 September 2009 - 08:05 PM
Posted 17 September 2009 - 09:43 PM
the 1750 O series was in the maxi and some allegros, there was also 1500 O series.
the 2200 landcrab was a 6 cyl ohc, prettu sure it was an O series with 2 more cyls, still only had 110hp...
Posted 01 October 2009 - 07:44 PM
1800 B series was in the 1800 landcrab in transverse for as mentioned,
Wasn't there a 3.0 version put in the Austin 3.0 (Land Lobster)
