Battery Draining?
Posted 31 July 2009 - 12:11 PM
I found this guide on how to fit a stereo
http://www.theminifo...showtopic=11215
was very helpful and all went well. However I noticed this morning that after not using the car for a day it struggled to start. I was wondering if the constant power connection could be enough to drain the battery, maybe the battery was not meant to be used with a stereo?
Any thoughts would be appreciated
Posted 31 July 2009 - 03:34 PM
i find if i remove the front face of mine the current draw goes from 0.1 A down to 0.01A
might be worth a try
Posted 31 July 2009 - 03:59 PM
Posted 31 July 2009 - 04:29 PM
also the cd player should have came with a small manual
and should say how to wire the unit
Edited by joakwin, 31 July 2009 - 04:35 PM.
Posted 31 July 2009 - 05:45 PM
Not sure about the memory, not as far as I know. It’s this stereo: http://www.minidisc....MDX-CA680X.htmldoes the stereo have a memory built in ?
The front has been off the whole time.i find if i remove the front face of mine the current draw goes from 0.1 A down to 0.01A
I’m pretty sure the wiring is correct; it only turns on when key is turned.could be your wiring..as mine was the same..only way is to either leave it unplugged or switch the yellow and the red wires over
I was thinking about unplugging the continuous, would this cause a problem? Or maybe moving the continuous to position 1 and the position 1 to position 2?
Posted 31 July 2009 - 11:42 PM
Posted 01 August 2009 - 07:23 AM
Posted 01 August 2009 - 07:40 AM
Posted 03 August 2009 - 06:01 PM
Good question ... the left side
Fuse won't be the cause a fuse is a protection against excess load.
Depending on the age of the Mini - if your fuse box is the 4 style set then remember many other parts of the car are feeding off it.
Having an in-line fuse on the Radio rated correctly means if there is a fault its not going to take out the main fuse with it.
1st thing I would check is if you can turn it on with the ignition off - if you can that would indicate your main V+ is wired to your permanently live.
I assume were talking radio only - no additional power amps etc.
Edited by PMM, 03 August 2009 - 06:03 PM.
Posted 03 August 2009 - 07:30 PM
It's 1995. Nope, you can't turn it on with the ignition off. Yeah, it's just a head unit.
Posted 07 August 2009 - 05:26 PM
Posted 12 August 2009 - 05:55 PM
I went on holiday for a few days (with the car) and while I was there I left the car, unused in a car park the whole time. When it was time to come home it started fine. On the way home I had the stereo on, the sat nav charging (I've fitted a cigarette lighter) and it was raining so I had the wipers, lights and demister on. I stopped for petrol, when I tried to restart the engine after filling up, the battery was almost completely flat. I would have thought after driving for an hour or so the battery should have been fully charged. Anyone got an ideas? Could there be an intermittent charging problem?
