Pedal Trouble
6 replies to this topic
#1 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 31 July 2009 - 07:07 PM
hiya,
the outside collar on the brake that attach to the pedals, has siezed itself to the inside shaft.
So the brake makes the clutch pedal move, i personally dont have a trouble with it as its not enough to cause any trouble, but Mr MOT man was'nt happy.
No i thought i would undo the nut and slide the shaft out...NO no that would be too easy.
However hard i hit the thing with a hammer the shaft will not budge,
Has any one got any ideas on how to
Remove the Shaft
OR
Free the bedal so it doesnt interact with the clutch.
Alastair
#2 liirge
liirge
  • 4,097 posts
Posted 01 August 2009 - 12:16 AM
Anyone got any ideas?
#3 liirge
liirge
  • 4,097 posts
Posted 01 August 2009 - 10:16 PM
Please someone must have an idea...
#4 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 01 August 2009 - 10:42 PM
try freezing spray and penitrating oil together
dave
#5 newdawn1st
newdawn1st
  • 1,268 posts
  • Local Club: Fylde Mini Club
Posted 01 August 2009 - 10:51 PM
Before I continue, This was just a thought, which I don't think is the best idea but I'll say anyway as it seems simple enough.. could try wedging one of the pedals with a block of wood then stepping down on the other, which might force it free to rotate on the shaft.
Thought this was a bad idea though as the pedal box may break elsewhere with the extra force your trying to put through it or just as bad you put too much weight on the wood and buckle your toeboard.
or am I thinking too sensibly?
#6 liirge
liirge
  • 4,097 posts
Posted 02 August 2009 - 03:58 PM
I tried that one, and it moves, but the second i take the chuck away it starts moving the clutch pedal again. I really do think the only way is to move that shaft out, i just cant get it to budge..
#7 Ethel
  • 25,938 posts
Posted 02 August 2009 - 04:46 PM
I'm not sure you can rotate the shaft, is the pear shaped bit on the other end moving? If it is seized I think you'd need the pedal box off to get some heat and oil at it.
