A+ Series Block, Fitting To A A Series Remote Box
Posted 02 August 2009 - 09:42 AM
I need to know if it is possible to fit a remote A Series gearbox, to a A+ Series block. If it is possible, does anyone on here run this set up? Does anyone have problems with it?
The engine could end up putting out around 150bhp with straight cut gears and drops.
I did try to search but its a bit of a weird one.
Cheers,
Kyle.
Posted 02 August 2009 - 12:03 PM
Posted 02 August 2009 - 04:39 PM
You need the pre-A+ primary gear, or straight-cut gear set.
The reason it wouldn;'t work with an early 3-syncro boxd is because the larger big-end caps of the A+ hit the gearbox casing. It can still be fitted, but you have to machine away the 3-syncro casing in several places, which is what I've just done.
If you are going to get c.150 bhp, what is the engine spec? Presumably it's a forced induction unit.
Buy boxes of ear-plugs in bulk, you'll sure need 'em!
Posted 02 August 2009 - 06:22 PM
I've just done another one like that.
You need the drop gears (primary/idle/input) gears to match the gearbox ! A A+ primary gear WILL NOT fit the A series gearbox......
Posted 02 August 2009 - 07:06 PM
Thanks, Max
Posted 02 August 2009 - 07:16 PM
Posted 02 August 2009 - 07:22 PM
Thanks,
Max
Posted 02 August 2009 - 08:47 PM
Hi is it possible to fit an 1275 A-series engine to a 998 mini neon gearbox?
Thanks, Max
Sorry, is there any chance you could open your own topic up, so not to confuse this one?
Yep as long as it's not a 3 synchro box it'll fit fine.
Its a 3 syncro, straight cut box. Hmmmm, cheers.
So I need to retain the pre A+ primary gear, but use A+ drop gears?
So just need to remove material from the sides of the gearbox casing where the big ends would hit?
Yeah its going to be forced incuction, should be fun. Thanks for the advice.
Right o.k, so the A+ primary gear will not fit the A gearbox? Bit confused now.
Thanks for the help so far though guys, it looks like the biggest problem is the transfer gears. Hopefully someone can clear up the confusion ha.
If I manage to get all the knowledge I need, when I come to doing the converison I will write up a guide with pictures (unless one already exists) so that this may not be needed again.
So, question still stands of how to transfer power from the A+ engine, down to the A Series gearbox.
By the sounds of it though, cooperman has already done it, which is where I'm confused.......
Posted 02 August 2009 - 09:49 PM
Yes as above you need to grind out the the casing to clear the crank.
You need a set of A Series 1275 drop gears, you cant mix and match as A series and A+ have different teeth profiles. Plus the A+ idle gear won't fit the A Series casing.
By far the best way forward for you with any sort of decent power is straight cut, like this. These are timken drops which are the most reliable as they do away with any side loadings.
Edited by Nightrain, 02 August 2009 - 09:50 PM.
Posted 02 August 2009 - 10:08 PM
So I need to;
Grind out the casing to clear the crank
Fit A series drop gears to the A+ block
Yeah, I'm definatly going straight cut.
Thanks for the advice, if theres anything else people think I should know, just say.
Posted 02 August 2009 - 11:25 PM
Posted 03 August 2009 - 06:00 AM
Reason for keeping the remote is that I already have straight cut gears in there, and don't fancy buying another set. Plus I love the feel of the remote gearbox, I've got so in tune with it now I would say I'm not far off sequential gear change times, which is nice.
Thanks again,
Kyle.
Posted 03 August 2009 - 08:48 AM
It's just something that needs to be checked when going to SC drop gears.
They are so noisy that, in a way, I wish I had not done that. I did it after I stripped the idler gear on a rally, but it was the 31st event the car had done on the original helical drops. The increase in noise means that I have to use ear plugs on any sort of long road drive and I now tend to take the car everywhere by trailer to and from events. However, it doesn't 'arf go!
Posted 19 August 2009 - 07:14 PM
Question is how much do you need to grind away and number 4 is obviously the same, the case already has some marks by number 4 in it where a previous journal has rubbed. Does 2 & 3 give problems also.
If anyone has a picture of the grind would be appreciated as I want to get the engine in ASAP missing driving the mini so much.
thanks Rofert
