Boot Hinge, Help Please
5 replies to this topic
#1 rick.spi
rick.spi
  • 1,686 posts
  • Local Club: "WOT NO BRAKES"
Posted 03 August 2009 - 07:32 PM
my question is... is there different type of boot hinge things as mine dosnt pull the boot fully shut and there is a gap between the seal and boot, cant see any adjustment so is there different ones on different years?
annoying now and want to get it sorted as it has caused a whole lot of welding needing to be done around the boot floor
can anyone help please?
thanks.
#2 Cooperman
  • 23,367 posts
Posted 03 August 2009 - 07:45 PM
AFAIK all boot hinges are the same from 1959 to 2000.
#3 rick.spi
rick.spi
  • 1,686 posts
Posted 03 August 2009 - 07:46 PM
darn... why isnt it closing properly am i missing something?
#4 sam_1275_carbon_sprite
  • 90 posts
  • Local Club: REKT AUTOMOTIVE
Posted 03 August 2009 - 07:47 PM
i'm quoting from what i remember from a mini mag, if it doesn't create a seal, where the handle latches onto the body work, (behind the boot seal in the middle) there is a latch plate, if the door doesn't shut, bend it further in (so the door is tighter against the car when closed) alternatively, if it's a new seal, try and work it backand forth for a while, as the seals can be stif enough to stop the latch working properly,
hope this helps, sam
#5 rick.spi
rick.spi
  • 1,686 posts
Posted 03 August 2009 - 08:08 PM
cheers sam, i'll give it a go and report back to ya :errr:
#6 Doodling
Doodling
    Formally known as phil.lingard
  • 260 posts
Posted 03 August 2009 - 09:42 PM
If the gap in on the bottom then i remember you can get alloy spacers to fit on the hinges. Or the rubber gasket may be perished and compressed with age.
