I know nothing about car audio so will i be able to hook up two 6x9 speakers to my head unit without an amplifier? It will only be these two speakers nothing else.
Will I Need An Amplifier?
mini-beast
, Aug 06 2009 03:42 PM
5 replies to this topic
Posted 06 August 2009 - 03:42 PM
Posted 06 August 2009 - 07:32 PM
my 6x9 in my astra run straight off the headunit with no amp
although all the wireing was already done as it was left when i bought the car.
Mine are only budget ones but with some songs, you'd think there was a sub.
Posted 06 August 2009 - 09:02 PM
fine without
LOUDER WITH
basically its up to you, its easier to just wire the 6x9s directly to the head unit but you will get a louder better sound from an amp with a lot of bass if you want it.
hope this helps
LOUDER WITH
hope this helps
Posted 10 August 2009 - 07:35 PM
Thank you people!
Posted 11 August 2009 - 04:22 PM
plus, if you wire up an amp to the 6x9's, you save yourself from buying a subwoofer
and losing what little space the mini has left
Posted 14 August 2009 - 08:03 PM
If you have the time/inclination/resources/funds it is always worth getting an amp (in the same price bracket as the speakers; there's not a lot of point spending lots on an amp to go with cheap speakers or vice versa) and the install is very important too. I have mine mounted in my mini in the fairly standard way, under the back seats in an MDF board, got the rough dimensions off here http://www.miniproje...eaker_board.htm
It's a fraction of the system I used to have in my (more accommodating) Golf but really pleased with how it sounds. The Speakers and amp are fairly middle of the road too, nothing special.
