Rebuilding 1275 Mg Metro Engine
10 replies to this topic
#1 drummerian
drummerian
  • 1,674 posts
Posted 09 August 2009 - 11:35 AM
Hey people,
So here is my current engine plan for the next couple of years:
Current: 998cc stage 1 (i have brought a nice stage 3 head and twin hs2s, however, then i found the 1275 going cheap and decided this would work better...?)
This means i do have the bits above for sale ^ :D
This summer build: 1275cc mg metro engine, keep it std(ish) to reduce insurance.
Next few years, rebuild a nice Micra engine and shove that in (i am told it is a nice engine swap if it's your first non a series)
Anyway so that is the plan...subject to change :teehee:
So this summer i will be rebuilding my 1275cc engine (i use the car daily so i need it to be reliable). Although i build most of my 998cc engine last year i would like to go the full way with this a series, so i can learn even more about it than last time. I'm thinking i will rebuild the head and stuff.
Currently got:
1275cc Engine and Gearbox
LEADED head
Ancillaries from my 998 (is there any that are different)
Metro electric dizzy
Spark plugs :dontgetit:
HT leads
2x hs2 twins (Could i use these on the 1275??)
What i need:
Bits to create an unleaded head (is this worthwhile doing?)
Possibly a carb (if i can't use hs2s)
Exhaust manifold (can i use my old backbox? is it jus the manifold that will restrict?)
Piston rings
Main bearings
Big end bearings
Gaskets
So what i really need is tips and advice on any bits i should be buying that will increase power(without increasing insurance) andd increase reliability. Also any good tips like david vizards of carb modifications would be useful! (yes i am attempting to get hold of the book!)
#2 Cooper-202S
Cooper-202S
  • 201 posts
Posted 09 August 2009 - 12:19 PM
For a Relatively Inexpensive work up the following will yield appreciable results.
1) Use your leaded head as an exchange for a converted head, or have it done. Unless your in the engineering business it not a Diy job. Better to go stage 2-3 and get the inlet manifold matched to the head. Spec it for 10.1-1 compression.
2) Fit an LCB rather than play with the existing exhaust manifold
3) If you’re having the crank reground for new bearings spend the extra £70-100 to get in wedged and rebalanced, this will lighten the whole bottom end and is the equivalent to shaving 40-50pound off the rest of the car.
Work up the flywheel assembly as well for optimum results
From the insurance point of view all you need declare is that it is a 1275 cooper spec engine with an lcb and stage 2-3 head because that’s precisely what it is.
#3 drummerian
drummerian
  • 1,674 posts
Posted 09 August 2009 - 01:01 PM
Thanks for the advice!
which carb would you go with?
I was still thinkign of keeping it more or less std. to jeep insurance down....i will do a few quotes to see what kinda price i will pay though!
#4 Cooper-202S
Cooper-202S
  • 201 posts
Posted 09 August 2009 - 02:10 PM
"which carb would you go with?"
Bearing in mind this is your daily drive
For ease of tuning & reliability a single Hs4, for performance the twin carbs
but they will need more work setting up and more regular servicing to keep them in tune.
Single carb will be cheeper to insure!
#5 Pauly
Pauly
  • 4,213 posts
Posted 09 August 2009 - 02:35 PM
A HIF44 will be a better carb than a HS4 the HS4 will stangle power.
Paul.
#6 drummerian
drummerian
  • 1,674 posts
Posted 09 August 2009 - 03:07 PM
i suppose a hiff 44 would be more reliable and cheaper insurance...
#7 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 09 August 2009 - 03:41 PM
I believe the best all round carb for a larger bore engine, decent economy, decent power, quieter than a webber.
Ben
#8 drummerian
drummerian
  • 1,674 posts
Posted 12 August 2009 - 04:58 PM
will attempt to acquire a hiff44 then >_<
anything else i should be considering?
#9 greggy50
greggy50
  • 435 posts
Posted 12 August 2009 - 05:44 PM
How much you looking for the head and the carbs out of interest?
#10 drummerian
drummerian
  • 1,674 posts
Posted 12 August 2009 - 07:13 PM
not sure yet mate, the head is brand new...make me an offer?
#11 greggy50
greggy50
  • 435 posts
Posted 12 August 2009 - 09:43 PM
Is it okay if I get back to you monday need to sort some funds out first really >_<
