Respray In Garege At Home
9 replies to this topic
#1 mk=john
mk=john
  • 1,167 posts
  • Local Club: Milton Keynes Mini Club, Mini Cooper Register
Posted 11 August 2009 - 05:15 PM
Hi
I plan to respray my mini in my detatched gararage at home. I plan to use extra lighting and extractr fans etc. the garage is 10 ft wide, by 15 ft long (useable length)
if anyone here has done this before, can you please advise me on what extrator fan and lighting to use, and where to get them from? I will plan to line the garage with polythene sheets etc.
John
#2 jack_marshall
jack_marshall
  • 2,540 posts
Posted 11 August 2009 - 05:53 PM
Did you decide to paint in cellulose?
#3 mk=john
mk=john
  • 1,167 posts
Posted 11 August 2009 - 06:04 PM
Hi Jack
Yes, it will be celly, both primer and topcoat
#4 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 11 August 2009 - 07:23 PM
Hi Jack
i resprayed my mini on the side of the road, out in the sunshine, with no lined garage, no extractor fans, no fancy spray booth, n it turned out well! just needs to be polished up and sorted! gave it 6 coats of celly to, so plenty of paint to polish up! sorted!
  • Attached File  8.jpg   59.78K   14 downloads
  • Attached File  10.jpg   56.92K   18 downloads
  • Attached File  20.jpg   73.19K   37 downloads
#5 Frog
Frog
  • 492 posts
  • Local Club: Blakehill Mini's
Posted 11 August 2009 - 07:56 PM
Hi
John
I sprayed cars in my prefab garage for 15years, all I did was put extra florescent tubes up & used to used a radiator fan to start with mounted to a piece of wood, later replaced with a clark extractor from machine mart. I never used to line the garage just gave it a good clean out then wetted the floor realy well before starting. Always seemed to work well.
#6 mk=john
mk=john
  • 1,167 posts
Posted 11 August 2009 - 09:54 PM
Hi
John
Hi, does your clarke extractor have the charcoal filter? Do you have the model number at hand?
#7 Brams96
Brams96
  • 2,308 posts
Posted 13 August 2009 - 05:58 AM
How did you set up the fan? Wont using an extract fan in a sealed garage suck in air (and dust particals) from any gaps from outside??
#8 Frog
Frog
  • 492 posts
Posted 13 August 2009 - 12:36 PM
Hi
John
Hi ,
No charcoal filter fitted I just made up a filter in a wooden frome that screwed over the top. You can buy a 1m x 1m piece of filter from you local paint factors. The fan itself was a 10" CAF304 but they are quite expensive.
#9 jjojjas
jjojjas
  • 272 posts
Posted 16 August 2009 - 07:38 AM
I did mine in the garage. The lights were just fleurescent ones, but I had the car a little too close to the door and it cast a very slight shadow....when all was done I got two runs in the paint, both where the shadow was cast , I just didn't see them with the light. So make sure your lighting is good.:D
I masked mine of woth poly sheet. It worked very wee, but if I was to do it again I'd also put it on the floor. It would have made the clean up a lot easier.
Finally, I did not have any extraction. The result was ok for me, but it has still got some overspray on it. If your after a concourse spray job with little or no polishing I'd get some extraction sorted.
Good luck. I'm pleased I did mine, but I'm not sure I would do it again.
:P
#10 mini.cooper998
mini.cooper998
  • 685 posts
  • Local Club: looking
Posted 16 August 2009 - 03:39 PM
nice colour jjojjas is it smoke grey,
did you spray celly or 2k and how many coats of each
thanks
andy
as regards your fan do you suck or blow er misses
Edited by mini.cooper998, 16 August 2009 - 08:40 PM.
