Cam Update.
22 replies to this topic
#16 Mr Joshua
Mr Joshua
  • 378 posts
  • Local Club: Rebels mini club
Posted 15 August 2009 - 12:04 PM
If you use a 276 you have all the down sides of the 286 but none of the benefits.
Look here:
http://miniclassic.y...ewtopic/id/5261
edit: to insert link
Edited by Mr Joshua, 15 August 2009 - 12:05 PM.
#17 jaydee
jaydee
  • 8,565 posts
Posted 15 August 2009 - 01:20 PM
Danuneek..can you post your engine number?
#18 Danuneek
Danuneek
  • 452 posts
Posted 15 August 2009 - 03:33 PM
12A2EF77 243075
#19 jaydee
jaydee
  • 8,565 posts
Posted 15 August 2009 - 04:42 PM
Uhmble..12A2E its an spi engine, you've done the carb convertion?
For road use u'll have an improvement with all the kent 266, sw05, mg metro cams.
#20 Danuneek
Danuneek
  • 452 posts
Posted 16 August 2009 - 01:17 AM
yeh have done the carb conversion. So you think its between the 266 and sw05, which of the two would you go for?
#21 jaydee
jaydee
  • 8,565 posts
Posted 16 August 2009 - 09:27 AM
personal opinion..swiftune all the way..sw05 its a mild cam, not aggressive, with a great drivability at low revs, basically you'll have the same power under 3k rpm, with extra power above 3k up to 6,5k rpm. Thats good for a road car, on the road you need power and torque at low/midrange, unless you want to drive a screamer on the streets..
#22 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,154 posts
  • Name: Sean
Posted 16 August 2009 - 12:45 PM
I've got an sw5 in my small bore, and it is very mild!!
When I pull the engine next its coming out and a 276 going in.
For my 1330 in Spudnik I'm gonna be going 286.
For a 1275 I wouldn't even consider the sw5, may as well just use an MG metro cam!!
#23 jaydee
jaydee
  • 8,565 posts
Posted 16 August 2009 - 07:31 PM
I know what you mean, the sw05 is a bit tame, thats why im evaluating the kent 256 for my small bore (either sport and road use).
The mg cam is great for the 1275 and the kent 266 will be good equivalent.
But i dont think the SW05 for 1275 engines has the same 244 duration with a 0,28 lift as for the small bore, it will probably be somewhere in the 250/260 range, otherwise would be pretty useless.
