Manifold Bolts On 998
Posted 13 August 2009 - 05:40 PM
Posted 13 August 2009 - 05:57 PM
Sounds like a bad idea but the thread in the head is 5/16 UNF thread.
Posted 13 August 2009 - 06:01 PM
I'd guess cap heads would make them easier to get at as well
Posted 13 August 2009 - 06:06 PM
You want to use a bolt instead of a stud?
I stick my socket in there and it's tight fit. Sometimes only the nut comes loose and sometimes the stud with the nut if I'm lucky. If the nut comes out only, I have to take a lot of time getting the stud out or the block won't come out. Isn't it a lot easier to just use a bolt? What is the downside in using a bolt? Also, what is the length I need?
Posted 13 August 2009 - 06:30 PM
Posted 13 August 2009 - 06:35 PM
Posted 13 August 2009 - 06:49 PM
Posted 13 August 2009 - 09:29 PM
This way, you can change the head gasket easily. I've done this for over 45 years and it's the best option IMHO.
I've never tried socket head screws, although that should work fine as well.
One other tip, if you file the inlet manifold so that the semi-holes for the studs/bolts, become slots you can lift the inlet manifold out without fully removing the bolts, just slide the manifold, complete with carb, back after undoing the bolts a few turns. I use locating dowels on my 1310 cc 'S' as the inlet tracts/manifold ports are enlarged and I don;t use the location rings. For dowels, the split roll-pins from the remote gear linkage, cut down in length to suit are fine.
Posted 15 August 2009 - 04:57 PM
Posted 15 August 2009 - 05:06 PM
Edited by bmcecosse, 15 August 2009 - 05:09 PM.
