Another Turbo How To!
Posted 14 August 2009 - 08:37 PM
I would be using mirage? manifold but anyone have a idea how much the turbo and other little bits can be had for?
Also is it possible to have a reliable engine with a decompression plate? Im wanting about 100 BHP so not mega power just nippy and hopefully reliable
Posted 15 August 2009 - 09:51 PM
Seen a set of metro turbo pistons and rods for £150 is that the going rate?
Sorry for all the questions but im trying to read as much as possible
Posted 15 August 2009 - 10:48 PM
Can't comment on the price with any authority but it seems a bit high to me considering what you might pay for a whole A series, or new pistons.
Posted 17 August 2009 - 09:14 AM
Please bear in mind this is assuming your engine/box is in tip top condition. It would also be good practice to at least rebuild your diff for peace of mind.
Posted 17 August 2009 - 10:28 AM
You won’t need to change the cam as the MG one is one of the best options for upgrades, the crank is just fine unless the shells are fubared.
Best advice is to price up the cost of building your short motor then look at the cost of buying one off the shelf from some where like Minispeed. I caution buying the components individually to do this from so called specialist companies as they take pleasure in dicking you around.
Posted 19 August 2009 - 05:56 PM
The MG Metro cylinder head was fitted with TAM 1059 exhaust valves and TAM 1061 inlet valves, your basic early stage of big valve head. The exhaust valves need to be replaced with ones suitable for a turbo application. You can get 29.2 after market valves suitable to the task from Mini Spares the inlets will be 35.6 and can be left in. You don’t need to do anything to the chambers unless you are trying to build in the option of going for monster power.
When you say i don't need to do anything with the chambers is this with the standard compression/pistons or with fitted low comp pistons?
Posted 28 August 2009 - 12:03 PM
You seem to be on the right lines, the main issue with an MG spec engine is the high CR. Std Turbo pistons are good but others will do.
Thats not true as both the MG and MG turbo have 9.4:1, the difference is in the thickness of the crown
Posted 28 August 2009 - 02:35 PM
The head castings are the same except for the machining for the bigger valves, so the chamber volumes will be the same. The compression is lowere by the dished pistons on a turbo. Or you could fit a cometic head gasket.The MG Metro cylinder head was fitted with TAM 1059 exhaust valves and TAM 1061 inlet valves, your basic early stage of big valve head. The exhaust valves need to be replaced with ones suitable for a turbo application. You can get 29.2 after market valves suitable to the task from Mini Spares the inlets will be 35.6 and can be left in. You don’t need to do anything to the chambers unless you are trying to build in the option of going for monster power.
Posted 28 August 2009 - 05:22 PM
Posted 28 August 2009 - 05:30 PM
Posted 03 September 2009 - 11:09 AM
Leaded MG Metro engines had a CR 10.5:1
Unleaded MG Metro engines had a CR 10:1
Posted 10 October 2009 - 11:10 AM
Posted 10 October 2009 - 11:41 AM
