Double Mpi Radiator
Posted 14 August 2009 - 09:50 PM
Dan
Posted 14 August 2009 - 09:51 PM
Posted 14 August 2009 - 09:54 PM
Posted 15 August 2009 - 01:02 AM
Posted 20 August 2009 - 06:33 AM
How the hell are you able to fit a full rad on the right hand side of the wing... what do you not have in your car.
I am stuggling to find a place to fit a 10 row oil cooler on my mpi, let alone a full radiator.
There is a dual core rad that is around £160 ish that some people say that will improve cooling, but I have yet to see the results to warrent spending £160
Mike
Posted 23 August 2009 - 11:42 AM
this will be the obvious answer.
Mike
hythe performance do an uprated mpi radiator, its roughly twice the thickness but fits using the original mounts. They cost £230 though. I had one, on a mildly tuned mpi (basically stage 3/works kit). NEVER needed to use the electric fan for general driving, only used it on the london to brighton run (waiting in traffic for ages) and on the North Devon Grand Tour. I had the fan wired to a seperate switch as had problems with it never cutting in when using the standard radiator.
