Removing Stickers
13 replies to this topic
#1 Minion Burn
Minion Burn
  • 153 posts
  • Local Club: Bergen mini owners
Posted 16 August 2009 - 07:58 PM
What's the best way of removing stickers from paint work?
#2 nordicmini
nordicmini
  • 293 posts
Posted 16 August 2009 - 08:04 PM
mayonnaise
#3 redhotmini
redhotmini
  • 1,607 posts
a hairdryer to warm it up, and just be careful when you peel it off. use some tar remover when you've finished to remove any residue thats left, then just clean the car and polish after. if the sticker has been on there for a while you might notice marks or a slight change in the paint colour, the polish might help to remove/minimize them.
#4 minikidx14
minikidx14
  • 1,387 posts
  • Name: Ross
Posted 16 August 2009 - 08:13 PM
insted of a hairdryer, you could also use hot water.
#5 Figs122uk
Figs122uk
  • 823 posts
Posted 16 August 2009 - 08:42 PM
Ive added and removed lots of stickers :lol: as you guys may know
... I use a hairdryer, and then some stuff called label remover Clicky... Believe it or not. To remove the sticky bits which are left.
#6 Minigirl
Minigirl
    With Steve
  • 1,109 posts
Posted 16 August 2009 - 09:11 PM
^^ yep best things a hair dryer and some tar remover. i used the autoglym stuff worked a treat ;) just make sure to wash it off afterwards
oh and dont try to do too much all at once. a small bit at a time is best but if you run the hair dryer all over the area then it gives the glue time to soften up so by the time you get to the next bit its a bit easier :lol:
Edited by Minigirl, 16 August 2009 - 09:12 PM.
#7 Adcuz
Adcuz
  • 843 posts
Posted 16 August 2009 - 10:26 PM
Another vote for hair dryer here too. Put the hair dryer on full heat/power and heat the area up. Then use your fingernail to carefully peel the sticker away. I used this method to remove 20+ year old stickers on my old City.
#8 jaydee
jaydee
  • 8,565 posts
Posted 17 August 2009 - 08:44 AM
Hairdrier is the way to go.
About the residues, im glad no one mentioned petrol, the crappest way to remove them.
Another use of WD40 is to remove the glue residues from bodywork.
Less aggressive than petrol, which yes, works wonders, but i wouldnt reccommend it at all because u'll need to t cut the paint degradated by petrol itself, so basically you have to do double work with a bad result anyway.
#9 RacingGreen
RacingGreen
  • 2,111 posts
Posted 17 August 2009 - 06:42 PM
If the stickers have been on a long while, then a hairdryer may not be strong enough to warm them up. If this is the case the best thing to use is a heat gun to warm them up.
Panel wipe or synthetic thinners is the best way to remove any glue thats left.
#10 Figs122uk
Figs122uk
  • 823 posts
Posted 17 August 2009 - 07:21 PM
Dont mean to contradict you. But i removed my 19yr old Mayfair badges & strips with just a hairdryer... May of been lucky.
#11 PaulF
PaulF
  • 160 posts
  • Local Club: HAMOC
Posted 17 August 2009 - 07:26 PM
wall paper steamer and then you wont have to worry about burning the paint
#12 RacingGreen
RacingGreen
  • 2,111 posts
Posted 17 August 2009 - 08:39 PM
I didnt say a hairdryer wouldn't be strong enough. I said it may not.
It all depends on how the car has been stored, how old the stickers are. how long after paint the stickers were fitted and type of vinyl. You wont know untill you come to remove it. No one car will have exactly the same life as another.
#13 roofless
roofless
    Sticker Pimp
  • 7,215 posts
  • Local Club: central minis
Posted 17 August 2009 - 08:45 PM
:) bit extreme?? low temp hairdryer and some small degree of patience always works. may leave residue but it'll clean off with panel wipe if your brave or T-cut if your not.
people can get a bit carried away with hairdryers, and the modern Nicki Clarke jobbies and similar could melt rock at 20 paces from what I've seen of the misses on a rush job of a bouffant.
take it gently and be patient.
;D
#14 Senile Old Git
Senile Old Git
  • 2,409 posts
  • Local Club: Rutland Minis
Posted 20 August 2009 - 07:42 PM
hairdryers, hot water .... really chaps
Call Jawel Paints on 0121-558-6191, they will sell you a stripe removal tool, basically its a big round rubber that goes into the chuck of your power drill, this will remove stripes and any L.E. decals in minutes without any damage to 2k paint.
It did though, start to melt old cellulose so be gentle with it!!
