10 Inch Weller Wheels
7 replies to this topic
#1 darren10_3
darren10_3
  • 114 posts
Posted 17 August 2009 - 05:01 PM
hi there i wrote a new topic because on saturday i got some weller 13s which later found out pcd is wrong for a mini there 114s not 100 silly me. but bmc spoke to me and was quite blunt which i guess is good because u learn from others mistakes basicaly i have my eyes on some wellers 10x6 i no i need to buy the conversion kit from mini sport to make it run on 10s but is there any thing else i need to do as well to get 10 by 6s to fit chears
#2 Asphalt
Asphalt
  • 2,173 posts
Posted 17 August 2009 - 05:48 PM
1st: a Mini's PCD is 4" -> 101.6mm!
2nd: depends on what brakes you'r currently runing... Drums on front will be fine, as will 7.5" & 7.9" disc brakes. Anything larger and they don't fit. Rear brakes fit any size wheels (except wide wheels need the 'spacered' type).
So basicly: we can't tell you unless you've told us what's on your Mini ATM ;D
#3 navyseal
navyseal
  • 50 posts
  • Local Club: malvern modified minis
Posted 17 August 2009 - 05:50 PM
Depends on engine size. A good mate ran drums on his 1275 and they used to smoke like mad when it rained (as they got wet). Anything bigger than a 998 is best on discs.
#4 Asphalt
Asphalt
  • 2,173 posts
Posted 17 August 2009 - 06:02 PM
Of course!! I meant it like "if your car has drums on front - the wheels will fit". Assuming he's not runing a 1275cc+ engine if the car's allready on drums :)
I guess noone will be mad enough to downgrade from 8.4" discs to drum brakes, especially with a powerfull engine (850cc+ if you ask me ;D)...
Edited by Asphalt, 17 August 2009 - 06:03 PM.
#5 darren10_3
darren10_3
  • 114 posts
Posted 17 August 2009 - 06:12 PM
my mini sat on 12s at moment and its got disc on front standard size for 1993 mini what i ment by what willi need to do as in like do i need to cut archs or chang shocks or change steering rack to put 10 by 6 on
#6 navyseal
navyseal
  • 50 posts
Posted 17 August 2009 - 06:21 PM
You'll need to modify the arches so the wheels dont catch on your turning circle, easy enough job. Other than that, theres nothing I can think of.
#7 darren10_3
darren10_3
  • 114 posts
Posted 17 August 2009 - 06:27 PM
okay can u get templates or something to do this
#8 navyseal
navyseal
  • 50 posts
Posted 17 August 2009 - 06:29 PM
Nope. Each car ive done it on differs. Depends how the panels fit, wheels alignment, size, width, fitting etc etc
