Hiff 44 Recon
3 replies to this topic
#1 stevo-1991
stevo-1991
  • 227 posts
Posted 20 August 2009 - 06:51 PM
hi wonder if someone could help me ? i have a hiff 44 carb off my 1380 engine does anyone know of any companys in the north that do recondonitioned units or will reburished my old carb .
cheers steve
#2 bmcecosse
bmcecosse
  • 9,699 posts
Posted 20 August 2009 - 07:29 PM
Most unusual for an HIF 44 to be 'worn' so much it needs a re-con. What's wrong with it ? Probably easier/cheaper to just get another good secondhand unit.
#3 stevo-1991
stevo-1991
  • 227 posts
Posted 20 August 2009 - 10:48 PM
i took it apart today for a clean to find that the previous owner hadnt looked after it at all . the float chamber had siezed & a little screw has been snapped off & half of the thread is still in the hole the whole carb smelt of thinners i dont know if the prevoious had tryed to clean it & just given up & bolten it back together or it had been sat for a while & the fuel had gone off ?
ive bought a recon unit off ebay looks good & has had a total recon of all its parts . should it be a bolt on job & then set the mixture & i should be alright ?
also how would you tell if someone has changed the needle in a carb to suit the engine spec ?
steve
#4 jaydee
jaydee
  • 8,565 posts
Posted 20 August 2009 - 11:56 PM
You can get a rebuild kit from most suppliers, even minispares are selling genuine su kits.
I'd get one with a plan butterfly, and for needles, try starting with BDL or BBW.
Getting hold of a copy of 'tuning su carbs' and a hynes manual its definately worth, if you arent experienced with SU it you wont be able to do the initial settings.
