Wet Or Dry Suspension?
Staxxman
, Aug 25 2009 05:11 PM
7 replies to this topic
Posted 25 August 2009 - 05:11 PM
I've been told by a mechanic that it's best to avoid a Mini with a wet suspension. I'm sure there are different opinions on that, but my question is, what years/model have a wet suspension, and what years/model have dry?
cheers
cheers
Posted 25 August 2009 - 05:13 PM
dry handles better, but i think wet smoothes out the bumps alot better, but surely you want a mini for corners?
wet isnt as reliable as well, lots of things to break.
Posted 25 August 2009 - 05:19 PM
"Wet" also known as Hydrolastic is what you would find on some original 60s minis, not every mini from the 60s was on wet though
Posted 25 August 2009 - 05:27 PM
Was it just the 60's then that had wet?
Posted 25 August 2009 - 05:34 PM
1964 to 1969 I think, it was the mark 2s.
Posted 25 August 2009 - 06:17 PM
Hydrolastic was introduced in September 1964 on Mini saloons - Vans, Estates, Pick-ups were always dry.
For most saloons hydro was discontinued October 1969 when Mk 2 production ceased except for the Clubman, 1275 GT and Cooper S. It was finally deleted late June/early July 1971.
It is much more comfortable than rubber suspension and doesn't give that many problems.
Posted 25 August 2009 - 06:35 PM
Cheers, very helpful. I was just told that if they do go wrong, it's a big job to fix them.
Posted 25 August 2009 - 06:49 PM
If it does go wrong, it depends on the fault - the passenger side front displacer is a pain to replace as the union is behind the radiator/engine. The front to back pipes are also awkward as you really need to drop both subframes but if you've got a hydro car and the suspension is up I certainly would swop it to dry.
Parts are not hard to find except genuine Cooper S displacers - and one of those sold on eBay the other week for £15!
Handling wise, if you have competition bumpstops all round and shockers on the front then its as good as a dry set up but more comfortable.
