8.4 Discs And Brake Calipers
Posted 25 August 2009 - 06:39 PM
Posted 25 August 2009 - 06:41 PM
and your offset is ok...it could work...but who knows.
see what other peoples opinions are first
Posted 25 August 2009 - 06:43 PM
Posted 25 August 2009 - 06:45 PM
I would suggest you don't mess with the calipers, you can get a fiesta brake coversion done which is apparently a very good conversion for a mini and will allow for the smaller rims as well as uprating the brakes
Might be cheaper than getting it machined/filed
but with that conversion calipers still have to be machined...well the mounting bracket and something else has to be machined i think
although this will be the route i go lol
Posted 25 August 2009 - 06:49 PM
Posted 25 August 2009 - 06:50 PM
just having a read here, and had to ask, what do you mean when you say "machined"?
ground down slightly
Posted 26 August 2009 - 03:31 PM
This fantastic conversion from Mini Sport allows you to convert your Mini from running 12" wheels down to 10" wheels, for the "ultimate" classic look. Complete conversion includes discs, drive flanges, calipers, brake pads ready to build and fit.
is this really all il need or will i need offer parts and will it matter that im running a servo?
Posted 26 August 2009 - 03:37 PM
the new flanges are needed in order to centralise the disc (and caliper) within the wheel therefore the wheel will not rub on the disc or caliper
Posted 26 August 2009 - 03:38 PM
Has been done with good results, but theres a risk you damage the caliper.
Best get hold of cooper s discs and calipers or the fiesta 7,9" discs and calipers.
Posted 26 August 2009 - 03:41 PM
could always look in a local scrappy and see if theres any minis running on tens..and nab the brake setup of that
Posted 26 August 2009 - 03:46 PM
No need to change the hub when going down from 8,4" to 7,5".
Posted 26 August 2009 - 04:32 PM
so im just about to put my order in for my parts from mini sport im getting ebc cooper s 7.5 discs cooper s 4 pot alloy 7.5 calipers and green stuff pads but which drive flange do i orderCooper s setup kit come with 7,5" discs with studs fitted, drive flanges and obviously the calipers.
Posted 26 August 2009 - 04:41 PM
ive also machined down a set of mg metro 4 pot callipers myself, with an angle grinder and a drill, to fit over 7.9" vented and groved discs, it takes a steady hand, as u gotta re-drill the mounting bolt holes for the hubs, and grind certain parts off the calliper edge. i will be making a set up soon, as a guide for anyone else wanting 4pots on the cheap!
hope this helps!
lewis
