Fuel Regulator
Posted 25 August 2009 - 07:34 PM
My pump has been flooding out my carb so I did a fuel pressure test on it today and got the following results:-
Regulator all the way off:- 6p.s.i
Regulator all the way on:- 4p.s.i
I'm thinking my Filter King isnt upto scratch so can anyone recomend a decent fuel regulator?
Cheers, Lee
Posted 25 August 2009 - 07:46 PM
Posted 25 August 2009 - 07:49 PM
Right, I have a solid state pump and a filter king regulator.
Cheers, Lee
As far as im aware the filter king is designed mainly for the mechanical pump although i may be wrong.
You need one fo the regulators that the turbo guys use.
Same as this but if you look around you should find one second hand a lot cheaper
http://cgi.ebay.co.u...=item1e57603824
Posted 25 August 2009 - 07:52 PM
Posted 25 August 2009 - 09:00 PM
Posted 26 August 2009 - 06:58 AM
I seem to remember with Vac oporated stuff like the FPR (I believe the mini ones are) you need to turn the system off before adjusting, else it all goes a bit odd if you adjust it whilst its under pressure - I had an FSE boost valve on my old car, needed to turn the engine off before tweeking it
Great sounds good might put a bid down on that then.
If its a vacuum one where do I take my vac from ?
Posted 26 August 2009 - 07:12 AM
No it should be fine. I didn't see if you answered this before in your other thread but which solid state pump do you have? There are three, you need the 18 gallon/hour pump for twin 1.25 SUs really.
Posted 26 August 2009 - 05:05 PM
I dont have twin 1.25 su's I have a single HIF44 (1.75)
And I bought it as a 4p.s.i-5p.s.i fuel pump. But it clearly isnt as its pumping it at 6!!!
I wonder if perhaps its perhaps pumping it so high that the regulator cant keep up?
I think i'll go for the cheapest option first which is the pump.
Will either of these be better? : -
http://cgi.ebay.co.u...id=p3286.c0.m14
Edited by lawnmowercrap, 26 August 2009 - 05:05 PM.
Posted 26 August 2009 - 06:05 PM
