Once again, back for summer, so some real work can start again
discovered the engine i bought hasn't been converted to unleaded, so stripping and building the engine will have to wait until i've converted the head.
Been cracking on with some other bits though, mainly the turbo. First of all i rotated the turbine housing so the oil drain is in the correct place, which was more hassle than i thought, had to heat up the housing to rotate it.
Then cut the actuator tab in half and re-welded it on the other side as the actuator will be on the other side. (have also ordered a 7psi actuator so that i can run with the standard C/R for now)
Had to drill out the helicoils that were in the turbine flange so the studs from the manifold can fit through, and then finally i mocked it up on the back of the engine, and im very happy. The manifold needs a tiny bit of tweaking so the studs on the head line up with the manifold, however it's all good.
Obviously the compressor housing needs rotating upwards, but i don't have any circlip pliers big enough, so will have to beg/borrow/buy some.
So really the next job is to get the head converted, and clear up the garage so i can strip the engine down.
