7 Port Head Power Gain Over Cost
Posted 05 September 2009 - 09:58 PM
Posted 06 September 2009 - 10:44 AM
Posted 06 September 2009 - 11:25 AM
he sold the car when he moved on to racing somthing else.
Posted 06 September 2009 - 03:05 PM
Posted 06 September 2009 - 04:35 PM
Thanks for your offer! I want to use 45's of which i already have,Mill 750, I have a spare Weber DCOE 40 if you need it
Posted 06 September 2009 - 04:41 PM
Thought i might be pushing it about , Looked gentle into 8 port with Med soon added up cost wise not written it off cheers!I sprint a 1380 mini in a upto 1400cc class , over winter will be rebuilding, looking for a good power increase so was thinking of going 7 port. anyone using one might have any info .I am running about 123bhp at present , would like to get to 140+! sound possible? thanks
Posted 06 September 2009 - 05:21 PM
Posted 06 September 2009 - 05:25 PM
Posted 06 September 2009 - 05:28 PM
Posted 06 September 2009 - 08:34 PM
Tha age old problem! more power less reliability, i have got the bottom end pretty sorted but i know thats no complete guarantee, just looking for that little bit more , another age old problem!!!!Quite right. When you think that dimensionally the gearbox was designed to take 34 bhp and now we are putting 4 times that figure through it, albeit with some unreliability, it is quite remarkable, Yes, we have stronger gears and needle roller bearings where once we had plain bearings, but the overall dimensions have not really changed. It's a credit to its designers really, although we complain - well, I do as the transmission is the weak link on my rally 'S' which has about 117 bhp at the flywheel at 6400 rpm.
Posted 06 September 2009 - 09:05 PM
As i'm sure you know only too well - problem with all that power is holding the transmission together!
140hp normaly aspirated is naff all and the transmission will survive surprisingly well, as i am sure he is running a straight cut gearset
Infact, I have been running 140 hp on a standard well built transmission. That doesnt mean it wont go pop, but a rebuild at 5k is about due.
Posted 06 September 2009 - 10:08 PM
Mine shows 140+ at Southern carburettors and 150+at Pete Baldwins, pulls strong from 3,400 in 4th gear right upto 9,500.
Its more about how the head is modified and how well the engine is built than how many ports it has.
Paul
Posted 06 September 2009 - 10:35 PM
I have never come across a 7 port, 8 port or 16v that can stay within a second of my 5 port up the 1/4 mile (normally aspirated). Personally I see it as expensively unnecessary.
Paul
Hi Paul,
I have a 970 Cooper S motor that I want to get humming along better - and it is the upper rev range that needs improving.
What are the specs of your motor to get it producing that kind of power?
I would prefer to be able to use the 5 port rather than going to a different head.
Bevan
Edited by CobraV8, 06 September 2009 - 10:38 PM.
Posted 06 September 2009 - 10:54 PM
I run a turbo crank and A+ rods with as much weight taken off as I could to let it rev quickly - quite run of the mill really, but Im meticulus in my assembly.
Its the head thats the power producer. Basically its the best Swiftune could produce for me. it was expensive but no as much as buying a 7 or 8 port then having that modified.
Oh and a 310sp cam
Paul
Posted 06 September 2009 - 11:23 PM
Supra light weight car. I say Supra as in a whole other level of super
