I've been making some (very slow) progress on my Pro-Motive build but I've run into a problem that I was hoping someone on could help me with. For the life of me I cannot get the supplied exhaust anywhere close to being in position where I can bolt it on. There simply doesn't seem to be enough room between the frame and the differential housing to slide the exhaust tube between (it's right in the area of where the upside down "2" is on the attached picture. I spent probably a good two hours fiddling with it today and only managed to scuff up the exhaust wrap. Other than putting the exhaust in a vice to pinch it down some I'm at a bit of a loss as to what I can do to fix this problem.
Thanks,
Ryan
