Body Prep
3 replies to this topic
#1 Jackman
Jackman
  • 4,053 posts
Posted 07 September 2009 - 01:13 PM
Right i just want peoples opinion on this...
I have welded in a bulkhead so now i have some seams where the welds have gone.
The question is am i doing this in the right steps.
Welds cleaned up a bit.
Primed.
Seam Sealer across the edges.
Filler (I want to curve the edges of the joins.
Primer
Paint.
Would that be ok?
#2 miniQ
miniQ
  • 497 posts
Posted 07 September 2009 - 06:36 PM
hurrm better too clean with 36-120 grit then use body filler because filler bonda better to metal so...
clean&sand
body filler
sand & clean
seam sealer
e-poxy primer
sand & clean
paint
im a bit mudduled on hte seam sealer order though :/
Edited by miniQ, 07 September 2009 - 06:39 PM.
#3 Jackman
Jackman
  • 4,053 posts
Posted 07 September 2009 - 06:48 PM
Well thats the thing the seam sealer is normally used where two metal joins are, supposed to stop water getting in the gaps. Scuttle to wing join in example. Im not sure where to use it in the steps too.
#4 Jackman
Jackman
  • 4,053 posts
Posted 08 September 2009 - 05:19 PM
Bump.
