How To Install Distributor Driveshaft ?
5 replies to this topic
#1 M1N1C00P3R1275
M1N1C00P3R1275
  • 258 posts
  • Local Club: Minifinity
Posted 08 September 2009 - 08:25 PM
as above really thanks
its an A plus engine thanks
#2 M1N1C00P3R1275
M1N1C00P3R1275
  • 258 posts
Posted 08 September 2009 - 09:29 PM
bump
#3 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 08 September 2009 - 09:34 PM
I think it shows in the haynes.
Worst case you can just swap it round after, or swap the leads :thumbsup:
#4 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,147 posts
  • Name: Sean
Posted 08 September 2009 - 09:39 PM
Hey Cidre boy, long time no see
As I recall!!
- remove rocker cover
- Turn engine over by hand till the valves on cylinder 4 are rocking back and forth
- Install dizzy drive(with the largest segment upper most) so it looks like an analogue clock showing 20 to3
Unless the engine and head are both off the car then set the engine at top dead centre(no 1 piston at top of stroke) and then set drive at 20-3
Hope this makes sense
Shifty
#5 M1N1C00P3R1275
M1N1C00P3R1275
  • 258 posts
Posted 08 September 2009 - 10:02 PM
As I recall!!
Shifty
thanks,
the engine is out , by the way
#6 mk1leg
mk1leg
  • 9,343 posts
Posted 08 September 2009 - 10:30 PM
here you go....................
good luck..................and use a 3" long bolt to install dizzy shaft.................. :thumbsup:
