What Is This Hole? In Engine Block?
3 replies to this topic
#1 L.Hurst
L.Hurst
  • 192 posts
  • Local Club: BMC
Posted 09 September 2009 - 03:01 PM
I am rebuilding an engine, I have just put cam in, and also just put on a plate on the side of the block.
But I was just wondering what this hole is? I cant find or see anything which goes into it, there is no thread or anything in it. I just in a hole which goes from the timing chain into the block.
Can anyone explain to me what this is?
(middle hole, inbetween crank - top, and cam bottom)
Posted Image Posted Image
Edited by L.Hurst, 09 September 2009 - 03:01 PM.
#2 01smartc
01smartc
  • 1,412 posts
Posted 09 September 2009 - 03:27 PM
Its just a hole for the oil to pass through i think
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 09 September 2009 - 03:30 PM
First off, that's the front of the engine not the side. It may seem wrong because of how the engine is mounted in the car but if you refer to that as the front all the time it will be much easier to understand everything as you build.
That hole is a breather essentially, it allows for the pressure to equalise between the timing chest and the crank case and allows the crankcase ventilation system to draw right through the whole engine.
#4 L.Hurst
L.Hurst
  • 192 posts
  • Local Club: BMC
Posted 09 September 2009 - 04:02 PM
Ok thanks for that guys.
I was just checking to make sure that nothing is missing or needed to go there.
