as the title says really i will not come out i need to replace the hoses
hope you guys can help me out once again lol
cheers
josh
Help! Again Cant Get The Brake Hoses To Undo The Banjo Bolt On Subframe
josh.evans
, Sep 09 2009 03:56 PM
8 replies to this topic
Posted 09 September 2009 - 03:56 PM
Posted 09 September 2009 - 05:31 PM
undone it?
Posted 09 September 2009 - 06:19 PM
ive undone the brake hose that goes on the top but just cant seem to undo the bolt
cheers
cheers
Posted 09 September 2009 - 06:31 PM
more grunt needed - it'll move...
Posted 09 September 2009 - 06:41 PM
yeh but the more i push it the bolt on the hose is rounding off
josh
josh
Posted 09 September 2009 - 08:43 PM
Apply heat - or hacksaw!
Posted 09 September 2009 - 08:58 PM
freeze it
Posted 09 September 2009 - 10:12 PM
freeze it?????????????????????????????????????????????????
Posted 09 September 2009 - 10:39 PM
You mean the rubber pipe to subframe one?
As in the one from the wheel brake to the subframe solid pipes?
I grind them off from the bottom. Just grind it off to alomost all off, then tap the rest of the bolt off with a punch,
