A Series Rwd ?
7 replies to this topic
#1 crazirob
crazirob
  • 650 posts
Posted 09 September 2009 - 05:36 PM
Has anyone made a van/ pickup/estate or any A series mini rwd with the engine still in the front ??? if so can u post pictures
Robbie
>_<
#2 petwar
petwar
  • 241 posts
Posted 09 September 2009 - 05:40 PM
ive seen rwd stuff but its always had a big motor in rather than an a series. if your gunna got to the lenghts to make one rwd why would you use a heavy old low power motor when you could use something bigger. Im pretty sure moggy 1000's can have A series and rwd lol!
#3 project mini chris
project mini chris
    have a break, have a...
  • 1,894 posts
Posted 09 September 2009 - 05:48 PM
austin a35's had 1098 a-series engines and rwd >_<
#4 AndrewJ530
AndrewJ530
  • 1,628 posts
Posted 09 September 2009 - 05:50 PM
Them moggy's i think will have had the in line a series motor not the transverse one in minis.
If you are really set on making a rear wheel drive a series mini, then sourcing an inline engine is probably the best way to go. Get rid of the transverse box.
Andrew
#5 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 09 September 2009 - 06:38 PM
Austin Ant had a 1275 Rwd, it was fed via a prop shaft it also had torsion bars!!
#6 dave21478
dave21478
  • 639 posts
Posted 09 September 2009 - 07:37 PM
I remember reading many years ago about some mini race series, which required them to use the original engine/box. They turned the engine 90 degrees, and used a cut down driveshaft bolted to the frame to block the front-facing pot joint so the diff transfered all power to the rear facing joint, which was bolted to a prop shaft and a back axle offf something I cant remember.
The gearchange was modded with extra levers to work via the 90degree turn.
Not really feasable in a road car, and if you are going to the effort and expense of builng a RWD car, you should use a more suitable engine.
#7 1293sleeper
1293sleeper
  • 805 posts
Posted 12 September 2009 - 09:27 AM
i looked into this and a mg midget is the best to use as the wheel base is the same as the mini plus you get a 1275 motor. i was going to do this to a riley elf just use the floor pan of the midget with shell of the mini.
#8 captainjack15
captainjack15
  • 3,925 posts
Posted 12 September 2009 - 12:05 PM
There was a Moke (in dis-repair) at IMM... It also had an 'A' Series engine at the front too! :)
