Experiences With Exhaust Systems
Posted 09 September 2009 - 09:03 PM
I'd be interested to hear of other people's expericences with exhaust systems comparing before and after performance especially with Maniflows.
I do find it a little too close to standard noise-wise, I wonder if I should've gone for a single box system or does anyone find that the noise improves (i.e sounds nicer) as the system 'beds' in with carbon?
Posted 09 September 2009 - 09:06 PM
Posted 09 September 2009 - 10:35 PM
I've heard there is no difference in noise between a single/twin maniflow around town but its noticeable on the motorway?
Also that a twin box can slow down the movement of the gas as it goes through two silencers where as the single goes through one but have heard the twin can be better?
Anyone with experience of Maniflow exhausts?
I did once have a single box maniflow on a mini, sounded great.
Edited by GreaseMonkey, 09 September 2009 - 10:43 PM.
Posted 09 September 2009 - 11:02 PM
Edited by Sherlock, 09 September 2009 - 11:03 PM.
Posted 09 September 2009 - 11:15 PM
is the twin box a better for performance than a single as it keeps a better back pressure, as a straight through exhaust isnt good for performance because of the lack of back pressure!
Edited by The_Mistro, 09 September 2009 - 11:16 PM.
Posted 09 September 2009 - 11:56 PM
4-stroke engines are not dependent on back pressure like 2-strokes are, it's more to do with gas flow & tuned exhaust length. For instance it's not wise to fit a 2inch system on a 998cc Mini because the exhast gas velocity will be too slow, but on a tuned 1275, it's fine.i have a twin box maniflow on mine, only from the cat back, but i think its better through the mid rev range than when it had the pea shooter on it!
Posted 10 September 2009 - 12:32 AM
Posted 10 September 2009 - 01:03 AM
With a good LCB exhaust manifold, it would certainly work ok, it's often difficult to come up with the optimum exhaust without experimenting, but I would give it a try, I have seen a 998 with polished/ported head & 948 cam run very well on a 2" system & although I would normally say that's too big, it was quicker on acceleration than my similar car with 1.75" system. Your engine in a moderate/highly tuned state will push more exhaust gas & the long stroke engine may help, I don't know the science behind this but it's all down to exhaust pulses, which is what led to the design of the LCB. Having seen how well the tuned 998 ran on a 2", I say go for it.is a 2" exhaust to big for a moderatly to highly modified 1098cc?
Posted 10 September 2009 - 01:28 AM
Oh, and it's a Cooper 1275 MPI.
Posted 10 September 2009 - 06:33 AM
i found the car would rev so much freely, it was if something was holding the car back before
i also found a tank of fuel would go a lot further
once things were set up the power went from a standard 62 BHP to 70 on a rolling road
Posted 10 September 2009 - 07:16 AM
Posted 10 September 2009 - 07:23 AM
I'm interested in this
No idea, we don't have any motorways here!
Well already sounding a little better noise-wise, as mentioned I expect it'll sound a tad throatier once its got some carbon in it.
when i ditched my standard rover exhaust (with cat) for a RC40 single box exhaust (no cat) +matching LCB manifold
Thats quite an impressive rise from just an exhaust system. Keith Calver suggests in articles that the standard cat is quite efficient but no doubt after 15 years the internals have either broken up or its lost its efficiency-that might explain the vast difference in performance.
Edited by dickster, 10 September 2009 - 07:29 AM.
Posted 10 September 2009 - 07:44 AM
i fitted a maniflow system designed for miglia racing to mine, with cat replacement pipe and stage 2 LCB. i found it made a more noticable feel to the performance compared to the DTM i had prior and a much nicer and slightly quieter exhaust note. here is what mine looks like on my MPI Cooper
Hey - do you have any more pictures of this system?
Re: power increase:
Don't underestimate the psychological effect of a 'sportyer' exhaust. Placebo-effect and such!
Or maybe you'r just more 'active' on the throttle now that you get 'rewarded' with good sound.
Anyways I think a good designed exhaust can improve erformance a bit. Less restrictive exhaust = less backpressure = more torque.
The truth is possibly somewhere in the middle (placebo & increse in torque) - Enjoy!!
Posted 10 September 2009 - 08:29 AM
Re: power increase:
Definately not and I was aware of the possible placebo effect, I also own a older BMW M3 so I am used to cars with real power and I understand the principles of torque, this was my whole point of the post, that the increase is definately real and completely unexpected-I fitted the exhaust thinking it would look better and sound a bit nicer I didn't expect there to be any difference in performance.
Edited by dickster, 10 September 2009 - 08:30 AM.
Posted 10 September 2009 - 08:36 AM
