Cam Drives? How Do You Know?
9 replies to this topic
#1 lance
lance
  • 123 posts
Posted 13 September 2009 - 10:19 PM
hey all... i am wanting to fit a kent 266 cam into my 998 mayfair... how do i find out what drive it is? pin star or slot?? i havnt a clue haha. its a 1987 mayfair
please help
thanks people :D
#2 jkjaxor
jkjaxor
  • 331 posts
Posted 13 September 2009 - 11:21 PM
might be worthwhile changing the oil pump at the same time, unless youve recently changed it.
#3 lance
lance
  • 123 posts
Posted 14 September 2009 - 06:17 PM
thanks... but still doesnt answer my question
#4 Rosslin Racing
Rosslin Racing
  • 2,408 posts
Posted 14 September 2009 - 06:21 PM
look at the oil pump end of the cam you will see a slot or a round hole with a pin through it.
Your new cam will be slot drive i would have said.
Edited by Rosslin Racing, 14 September 2009 - 06:22 PM.
#5 lance
lance
  • 123 posts
Posted 14 September 2009 - 06:35 PM
ah :o well the thing is i cant really look at it because its my daily driver... i just wanted to know what cam i would need then at the weekend fit it
#6 Rosslin Racing
Rosslin Racing
  • 2,408 posts
Posted 14 September 2009 - 06:42 PM
its most likely to be a slot drive, unless some else knows for sure
#7 lance
lance
  • 123 posts
Posted 14 September 2009 - 06:49 PM
ahh ok thanks mate :o anyone else know??
#8 THE STIG
THE STIG
    Da stig says, GO GO GO
  • 2,506 posts
Posted 14 September 2009 - 06:50 PM
if you have the original a+ engine fitted it would have come with a slot drive as standard
are you fitting the cam with the engine in place or with engine out
if with engine out then get a new oil pump as well
ideally you should fit new cam bearing when fitting a new cam although people dont seem to bother
#9 lance
lance
  • 123 posts
Posted 14 September 2009 - 06:52 PM
thanks mate :o... how hard would it be to do it with the engine still in??
The engine has only done 27k miles so i didnt think i would need to replace bearings or followers?
thanks
#10 THE STIG
THE STIG
  • 2,506 posts
Posted 14 September 2009 - 07:08 PM
can be done in the car on a 998 as can remove the tappet chest covers to remove the followers but is a pain as have to feed cam through inner wing and would have to cut a hole
did not know if you had a standard front end or flipfront
is far easier to do with engine out
would replace follows as well as are going to be worn to the other cam
if was me would be replacing oil pump and followers as well as the cam
