Hi, brought my mini a while back and for some reason the engine number on the log book is only five digits long and is nothing like the one on the engine. I am now not at all sure what engine i have and whther the mileage is genuine as its sposed to have done 55k but the shell looks like its done about 200k!! The number on it is ; 99HB81P139499. Thanks in advance for any help!!
Engine numbers??
adam c
, Mar 22 2004 05:03 PM
5 replies to this topic
Posted 22 March 2004 - 05:03 PM
Posted 22 March 2004 - 08:01 PM
engine no's are normally about 6 digits, where did you get the(99HB81P139499) no from, that looks more like a chassis no than an engine no.
to check your engine no, look just below no 4 spark plug and there should be a plate there with a no on it.
as for finding out its history, don't hold your breath sorry
Posted 22 March 2004 - 08:05 PM
The 99HB81 means its a post 1985 Metro engine. All engines from engine number 127432 says its an A+ engine and has ungrooved lower main bearings an no circlip on the gudgeon pins, producing a grand total of 42 HP at the crank.
Posted 22 March 2004 - 08:13 PM
thanks for the enlightenment rich, i will have a closer look at my engine no tomorrow now :grin: :wales:
Posted 22 March 2004 - 09:10 PM
Thanks very much guys - another mystery solved. Just wondering now, are these engines just as easy as a mini engine to modify or not, i have another mini and the engine looks absolutely identical? Will it have the same gearbox as a mini and will it be unleaded or not? If its not unleaded can i use a mini unleaded head on it? Thanks very much! :wink:
Posted 22 March 2004 - 10:35 PM
They are the same engine in the Mini and the Metro, both A+, tho the earlier minis had A series, but they are swapable.
