Tie-rod Tightening
16 replies to this topic
#1 Hughes
Hughes
  • 377 posts
Posted 15 September 2009 - 08:21 PM
Fitted my new adjustable bottom arms and tie-rods this weekend.
One thing has just occurred to me.... how tight should the nut at the subframe end be? Obviously it squishes the bush as you tighten it so its difficult to tell? I know there is a torque setting listed in the 'torque settings' sticky, but you cant get a torque wrench on there!
Any ideas?
H
#2 MRA
MRA
  • 7,607 posts
Posted 15 September 2009 - 08:53 PM
You can get tools that will fit on your torque wrench and fit over the nut on tie bars :)
However with the tiebar removed from car using "eye measurement" align the flat surface (bottom) of the nut with the step this is as far as you can go, and you MUST tighten them this far, now just check how much thread is sticking out at the end, (make a note) now fit it all together and tighten the nut up to the shoulder check that it all looks as it should :) You should be able to "feel" the nut tighten down on to the shoulder, but the visual check is belt and braces and helps to keep us all safe :)
#3 bmcecosse
bmcecosse
  • 9,699 posts
Posted 15 September 2009 - 09:00 PM
Fit poly-urethane bushes - and they won't squish!
#4 Hughes
Hughes
  • 377 posts
Posted 15 September 2009 - 09:06 PM
MRA - thanks so much. Useful response as always.
bmceosse - The outer bush is poly. It still squishes a bit!
#5 MRA
MRA
  • 7,607 posts
Posted 15 September 2009 - 09:08 PM
?? Then they are not tight enough ! the tie bar is designed to be tightened up to the step not doing so will create a potentially dangerous situation with the threaded section being unsupported. :)
#6 bmcecosse
bmcecosse
  • 9,699 posts
Posted 15 September 2009 - 09:09 PM
Aye - but not as much as the soggy rubber ones! To be honest I always tightened these up to the end of the thread on standard tie-bars !
#7 MRA
MRA
  • 7,607 posts
Posted 15 September 2009 - 09:19 PM
We have 4 differnet grades of rubber including the following......
Very soggy
slightly less than soggy
very much less than soggy
and nowhere near soggy .....
:P
I find polyurethane to be a very good material for suspension bushes until it wears out.... as it has a very rapid wear rate and can fail fairly quickly :)
Other synthetic and pure rubbers fail less dramatically but do not last quite as long...
Horses for courses :)
#8 bmcecosse
bmcecosse
  • 9,699 posts
Posted 15 September 2009 - 09:26 PM
Fit spherical bearings !
#9 GraemeC
GraemeC
  • 7,440 posts
Posted 16 September 2009 - 08:10 AM
Martin - should he not include the flat washer in his 'dry' build as this will also sit on the shoulder (whereas the the shaped washer will go over the shoulder if I rememeber rightly).
Another reason for ensuring that the tie bars are tightened down to the shoulder is that it will affect the caster settings. OK adjustable tie bars can accommodate this but it is still better to start with the same baseline every time.
#10 GraemeC
GraemeC
  • 7,440 posts
Posted 16 September 2009 - 08:12 AM
Make your mind up :)
#11 Cooperman
  • 23,328 posts
Posted 16 September 2009 - 11:39 AM
Use castelated nuts, do them up really tight until you know the washer is hard-up against the step, then drill through the tie bar and fit split pins.
#12 MRA
MRA
  • 7,607 posts
Posted 16 September 2009 - 06:18 PM
Oops :thumbsup: yes fit the washers
And absolutely to the second >_<
#13 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 16 September 2009 - 06:28 PM
funny you should be talking of this, had an embarasing situation on my way home from work today, where the nut on the passenger side decided to pop of the tie rod, luckily i was doing less the 5mph, or it could of been very nasty! lesson learned me thinks lol
#14 MRA
MRA
  • 7,607 posts
Posted 16 September 2009 - 06:33 PM
When you say "popped off" do you mean that the thread has pulled or the nut just unwound itself ? in which case did you not feel it pulling more to one side ?? :thumbsup:
#15 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 16 September 2009 - 06:39 PM
it unwound itself, it didnt pull to 1 side, not that i noticed anyway, n then next thing i knew, 'pop!' and my wheel was tucked behind the a-panel lol but luckily i didnt lose any of the bits and i was on my way in no time with the help of a jack and a spanner
