can anyone tell me which pipe stub, on the heater assembly, the valve goes to and which one is for the bottom hose?
thanks
Heater Hoses To Matrix
JA50N
, Sep 16 2009 02:29 PM
5 replies to this topic
Posted 16 September 2009 - 02:29 PM
Posted 16 September 2009 - 02:45 PM
I don't think it matters which way you connect it.
Posted 16 September 2009 - 02:49 PM
The pipe from the valve goes on the lower stub, the pipe from the bottom hose goes to the top one.
Posted 16 September 2009 - 03:10 PM
i have my stubs side by side. is the lower and higher for the earlier heaters, as mine is the fresh-air system
Posted 16 September 2009 - 03:21 PM
It won't matter much. It might bleed easier if the higher outlet is nearest the pump (bottom hose connection).
Posted 16 September 2009 - 03:27 PM
It doesn't really matter and you'll hardly notice any difference either way round.
However if I was analysing it I would put the outlet to the stub nearest the blower motor. That way the air getting blown through the matrix will be slightly pre-heated (by the coolant as it returns back to the engine bay) before it gets taken to a higher temp by the coolant coming from the engine.
Connected the other way round it could actually get cooled down again slightly.
