Vini The Black Thing.... Who Wont Be Black At The End!
396 replies to this topic
#256 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,738 posts
  • Name: Chris
  • Local Club: None
Posted 02 April 2012 - 08:15 PM
very good ross lol
#257 Andrew O
Andrew O
    Previously known as Andrewo330.
  • 1,425 posts
Posted 02 April 2012 - 08:22 PM
Any updates ?
#258 yeti21586
yeti21586
  • 3,738 posts
  • Name: Chris
  • Local Club: None
Posted 02 April 2012 - 08:46 PM
Well on sat me and dad struggled to get the bloody rear window in no matter how hard we pushed etc we tried for over and hour!!!!!
so did some research on here (anyone would think that people no stuff about minis on here lol) and people were sugesting using lube so i went and bought some tesco on lube (dad also asked me to buy bog roll at the same time, i did get some funny looks lol) so we just spent 15 mins with me and dad and my lil bro and have got it in lol YAY no pic as of yet but am well chuffed!!!!
YetI
cough cough!
#259 Andrew O
Andrew O
  • 1,425 posts
Posted 02 April 2012 - 09:07 PM
I have seen that aha
I meant anything else ;)
#260 yeti21586
yeti21586
  • 3,738 posts
  • Name: Chris
  • Local Club: None
Posted 02 April 2012 - 09:38 PM
lol no not yet fella, hopefully get the rear opening windows on soon then doors and dash then front screen then fill up with brake fluid etc then hopefully the alarm and elecy ignition will have been done and we can test the engine and also need to to do the undersealing
YetI
#261 yeti21586
yeti21586
  • 3,738 posts
  • Name: Chris
  • Local Club: None
Posted 20 April 2012 - 03:33 PM
Right lets re-do the update since it went missing when the illegitimate holes that frequent the nether regions of ones ass, decided to bugger everything up.
were was i..............
ah yes......
we have now got all of the rear windows in and on the car (rear screen and both opening rear quarters)
and ive been meaning to move the heater hoses for a while because they are hitting the peddles. so while i was trying to remove the hose from one of the pipes on the matrix,(which was well and trully jammed on there, not sure how i managed to get it on in the first place it was that jammed on) i lubed it up and pulled and twisted and then something gave way "YAY" i thought, unfortunately i had manged to snap off the blooming pipe off of the matrix so now i need new ends.
but it did mean i could get pics of the inside of the heater and show how my dad (the electrical genious he is) managed to turn the on/off heater in to a variable speed one like you get in modern cars by using a variable speed resistor out of a golf and mating it to the heater controls from my corsa dash.
so this is the resistor he got
he then stripped the plastic from around the blade terminals and worked out which blade reduced the current by how much and then did a smiliar thing with the control switch by fiddling with the wires and connecting them to resistor and the motor.
anyway he came up with this idea of were to mount it so it stays cool and is hidden etc.
and then once its all wired you push all the wires up through the hole the 2 normal heater power cables come through and attach a plug for easy removal
YetI
#262 davej
davej
    Kelly Jones
  • 985 posts
Posted 20 April 2012 - 04:04 PM
Looking really good, how far off are you from it being on the road do you think?
#263 yeti21586
yeti21586
  • 3,738 posts
  • Name: Chris
  • Local Club: None
Posted 20 April 2012 - 05:05 PM
that all depends on the weather and wether we have all the parts and wether i brake any more parts >_< .
but hopefully asap other wise my other half is going to have my balls on a plate and my dads other half is going to do the same to him
#264 davej
davej
    Kelly Jones
  • 985 posts
Posted 20 April 2012 - 05:52 PM
Haha my other half is going to do the same to me soon too. Good luck with it, look forward to more updates soon.
#265 iDemonix
iDemonix
  • 963 posts
Posted 20 April 2012 - 06:07 PM
How do you control fan speed?
#266 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 20 April 2012 - 06:21 PM
Jedi mind power
:trooper:
#267 yeti21586
yeti21586
  • 3,738 posts
  • Name: Chris
  • Local Club: None
Posted 20 April 2012 - 09:00 PM
with the controls from the corsa dash
so im using all of the 3 twisty bits like the ones in the pic below to controll the heater power direction and hot and cold
so there are a number of wires that come out of the back of it for the speed that then relate to the resistor pictured earlier and the resistor steps the power down etc
hope that helps a lil bit
will try and get pics tomoz of the dash controls not fitted
#268 iDemonix
iDemonix
  • 963 posts
Posted 20 April 2012 - 09:50 PM
Impressive upgrade. I'd like to do a variable fan speed mod to mine but don't like the look of the controls.
#269 Ace Alex
Ace Alex
    Formally known as Pedal Pusher
  • 330 posts
Posted 20 April 2012 - 10:52 PM
Fantastic rebuild and colour scheme! Those wheels compliment the choice of body colour. I'm liking the twin tank set-up and mk2 rear lamps.
Nice project :thumbsup:
#270 yeti21586
yeti21586
  • 3,738 posts
  • Name: Chris
  • Local Club: None
Posted 21 April 2012 - 08:44 AM
If your going to want to keep the original facia for the mini heater, then you would need a multi-poke/position switch with 4or5 positions including off. Then you should be able to our it in the same hole as the original on/off.
Cheers matey. Lots of people before I got the wheels coated tried to warn me off having a bright colour like that, but just like you they all agree it looks amazing!!!!! Fitting the second tank was a scary experience,having to cut a big hole in his body work , but we did it right do its all good YAY!!!!!!
