Vini The Black Thing.... Who Wont Be Black At The End!
396 replies to this topic
#301 davej
davej
    Kelly Jones
  • 985 posts
Posted 20 June 2012 - 09:21 AM
Any updates on Vini?
#302 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,738 posts
  • Name: Chris
  • Local Club: None
Posted 20 June 2012 - 09:49 AM
Dads nearly done the wiring, he got it to the stage (before buggering off on a 2 week holiday in Greece) were I can now fit the interior, but before I do that I've got to make some gromits up to fill the holes that he gear stick rods go through, which should of been done when we fitted the internal mech but we forgot so I'm hopefully doing that this eve and then cutting the insulation to size, and unbolting the fuse box and seat mounts etc and fitting the carpets then slotting the dash in and the centre console, but I've the got to wait till dads back so he can finish wiring up the switches and the dials, but before then I've got to buy a new speedo sensor thing for irridium gauge
Oh and I need to fit the exhaust and arches and the n get an MOT ahhhhh and then he will be finished yay
YetI
#303 davej
davej
    Kelly Jones
  • 985 posts
Posted 21 June 2012 - 10:29 AM
Not that far off now then, looking forward to some updates in a couple of weeks.
#304 yeti21586
yeti21586
  • 3,738 posts
  • Name: Chris
  • Local Club: None
Posted 24 June 2012 - 08:41 PM
Well me and the misses Got the insulation cut to shape, but cant fit it till ive sorted out the holes in the floor, and im going to wait till my dad is back from his holiday in greece (all right for some (bring on sept honey moon in thailand yay) luck sod) as a friends neigbour was an idiot last week and was working on his car just using the trolley jack and it fell on him. he wasnt found for 4 or 5 hours when his dad found him a lil bit squished and dead, so apprehensive isnt the word,
but i also nearly got the electric speedo sensor hooked up, yay i seriously can not wait to get him on the road
YetI
#305 yeti21586
yeti21586
  • 3,738 posts
  • Name: Chris
  • Local Club: None
Posted 14 July 2012 - 10:59 PM
Well today we got an early start working on Vini and we got  a fair amount done (In-between watching planes fly over the garden from Farnborough air show).
So we dismantled the gear linkage so that we could what rubber gromity type things so that when I drive through puddles water doesn't pee inside through the holes and that took a while, this does now mean that the interior can go in!!!
Once we had done that dad did some under-sealing before we fafed about attaching the exhaust and fitting it too far back so about 4inches of the exhaust stuck out the back and the back box was squished against the subframe, so we then had to drill holes in the subframe to mount the exhaust in a different place , but the drill wouldn't fit (it was on all 4 axel stands and the jack is crap so wouldnt lift it high enough) so we spent about an hour driving around places trying to find some were to buy a flexi or 90degree chuck drill bit drive thingy, couldn't find any were that sold one or had one in stock. We got back to the house and dad has a brain wave if we lowered the front of the car the back would pivot slightly and might be high enough!
So we did that and it worked, If only he had had that brain wave an hour before lol never mind
We got the exhaust on which is important!!!
YetI
#306 samg2007
samg2007
  • 499 posts
Posted 18 July 2012 - 11:01 AM
Yeti, I've been through your entire work log and I have to say, amazing work. It looks great!
What car is the dash out of? I dont think that question has been asked!
#307 samg2007
samg2007
  • 499 posts
Posted 18 July 2012 - 11:07 AM
Scratch that, it was asked, but you didnt say! Could you tell us?
#308 Deathrow
Deathrow
  • TMF IT Specialist
  • 5,744 posts
  • Name: Adam
Posted 18 July 2012 - 12:23 PM
It's out of a Vauxhall Corsa C looking at it.
#309 yeti21586
yeti21586
  • 3,738 posts
  • Name: Chris
  • Local Club: None
Posted 18 July 2012 - 03:58 PM
yep out of a corsa C , nearlly ready to put it in, if it wasnt raining i would be out there now, but the gazeebo is dead so cant pull him out to work in the rain any more grrrr bloody english weather!
#310 samg2007
samg2007
  • 499 posts
Posted 18 July 2012 - 04:39 PM
It looks great. How did you get the heater controls to work, I saw the bits in the other post about fan speeds, but how did you get the temp and air direction cables to work?
#311 yeti21586
yeti21586
  • 3,738 posts
  • Name: Chris
  • Local Club: None
Posted 18 July 2012 - 04:50 PM
that would be telling, lol well the hot cold one one the dash is a cable thing so thats just hooked up like it would normaly and the direction one is complitcanted and we havent tested it yet, but should work as ive taken the control rod off of the back of it and attached a cable clipey bit to it, which attaches to a boden cable that is bolted to the slider on the heater, will try and get pics at some point
#312 yeti21586
yeti21586
  • 3,738 posts
  • Name: Chris
  • Local Club: None
Posted 28 July 2012 - 04:07 PM
recently we have got the carpets in and the rear under seat speaker board in (i no that its not the best place for speakers but short on cash and i already had it so it will doo for now!) i did it at the same time as i was running the speaker cables under the carpet.
we have also got the interior light working with the door switches, and today we got both doors on, one is in the correct position and everything the other one is being a PITA! and already has 4 shims on the top hinge and none on the bottom but still needs to be moved over so need to add more shims to the bottom or top or something.
me and dad have done a fair amount of attaching wires so that things work with switches, like the reversing light works with the gear stick now and the brake lights work with the pedal.
I CANNOT WAIT TO GET HIM ON THE ROAD!!!!!!!!!!!! its been far to long
pics will follow at some point when i get my camera off of my fiance
YetI
#313 yeti21586
yeti21586
  • 3,738 posts
  • Name: Chris
  • Local Club: None
Posted 02 August 2012 - 08:11 PM
Right have got both doors fully on now we have 5 shims on the top hinge and none on the bottom , it needed abit of a twist and it's on yay, just need to wire up the electric windows and the central locking bits and the doors are done, also need to attach cir clips to parts of the Lock mech and then the doors will be done yay!!!!
#314 yeti21586
yeti21586
  • 3,738 posts
  • Name: Chris
  • Local Club: None
#315 yeti21586
yeti21586
  • 3,738 posts
  • Name: Chris
  • Local Club: None
Posted 03 August 2012 - 03:15 PM
Crappt iPhone pic
