Well i have a 1989 mini and it been in for mot and an advisory was to replace the gearbox stabilisers but where the hell are they and how easy are they to do?? im so stuck im new to the mini and dont no where to look
Any help is better than none many thanks
Robbie
Gearbox Stabilisers
robbie-woods
, Sep 16 2009 07:33 PM
5 replies to this topic
Posted 16 September 2009 - 07:33 PM
Posted 16 September 2009 - 07:51 PM
should have added its a 998cc pre verto im not sure if this helps
thanks
thanks
Posted 16 September 2009 - 07:54 PM
The most common fitment of gearbox stabiliser is found adjacent to the sump drain plug, (clutch end of engine) it is fitted to a flat bracket bolted to the bottom of the transfer casing & runs forward to the front beam of the subframe. Normally it is only necessary to change the bushes at the gearbox end, which is an easy unbolt-replace-bolt back job. The subframe end is harder to get to, a socket set with a universal drive can be a help. The alternative stabiliser fits on a bracket at the bottom of the gearbox on the radiator side (rear of gearbox) & runs to a hole in the frame under the driveshaft area, that is very simple to change. It could actually have both, I have done that on my Mini.
Posted 16 September 2009 - 08:01 PM
ok sounds easy enough i was told just the rubber bushes needed doing so i will have a look tomorrow
cheers
cheers
Posted 16 September 2009 - 10:44 PM
Always happy to help, if you have any more difficulty I'm usually around, but one thing I should say, if you just use your Mini on the road, stay with the standard stabiliser bushes, there are very hard alternatives for competition & hard use, but they transmit a lot of vibration into the car. Good luck with the repair & with your new venture into the world of Minis, I hope you get as much fun out of it as I have over the past 40 years.
Posted 17 September 2009 - 02:57 PM
Might be worthwhile checking the rubber mountings on the rear of the gear lever extension whilst you're under the car - they may have deteriorated as well.
