Thermostat Housing
Posted 02 October 2005 - 09:52 AM
Also, the other bolts wont come undone..... how do i get them undone?
Posted 02 October 2005 - 09:55 AM
If its flush, then you will have to drill and re-tap the hole. If its still sticking out then try plenty of penatrating oil and heat, with a pair of moles it will come eventually.
Posted 02 October 2005 - 09:59 AM
Posted 02 October 2005 - 10:30 AM
Posted 02 October 2005 - 12:47 PM
Posted 03 October 2005 - 12:45 PM
(Of course, in the U.K., t-stat housings are probably readily available and cheap. Over here, I'd have to mail order the part and wait 10 days to receive it. For you , breaking the cover to bits and installing new is a viable option to what I wrote in the paragraph above!)
Once the cover is off you need to extract what's left of the studs. First let me contradict what someone will certainly say in a future post to this thread. DO NOT try and use E-Z-Outs or whatever you call screw extractors. The stud has just sheared off in a rusty hole in the head... what chance does a hard, brittle, small diameter extractor have? You're inviting disaster with screw extractors. Heat the portion of the stud that is left using a torch. Get the end cherry hot if you can and then you can apply one of two things, penetrating oil or paraffin (wax... not oil). Yes, it might flame up, but not much. With the oil/wax applied to the stud, hit its top with a heavy hammer repeatedly. Repeat this heat, quench, hammer thing two or three time. Then start with the Mole (Vise) grips. Don't be tempted to back the stud out all the way at first. Wiggle the stud to loosen then tighten it in ever increasing arcs. You're trying to work the oil into what's left of the threads. Eventually it will feel free enough to back out. If it gets tight while backing it out, apply more oil and run it in again, then back out.
Be patient, work slowly. It will come out. If you've broken the stud off flush with the block, you're down to using the drill and re-tap method. If it comes to this, post again and I can bore you with details about that.
Posted 03 October 2005 - 04:02 PM
Posted 03 October 2005 - 04:15 PM
I am in Walton
Siggy
Edited by siggy, 03 October 2005 - 04:17 PM.
Posted 03 October 2005 - 04:27 PM
Thanks very much siggy.
Posted 04 October 2005 - 09:50 PM
Siggy
Posted 05 October 2005 - 06:47 AM
Posted 07 October 2005 - 07:12 AM
Siggy
Posted 07 October 2005 - 08:02 AM
