thanks
2001 Cooper Sport
Posted 20 September 2009 - 06:54 PM
Posted 20 September 2009 - 06:58 PM
Posted 20 September 2009 - 08:49 PM
Posted 20 September 2009 - 10:30 PM
Posted 20 September 2009 - 10:54 PM
Posted 20 September 2009 - 10:57 PM
I've noticed that Minis fitted with a solid mount kit at an early age still rust a bit, but don't crack like that.
Posted 21 September 2009 - 07:21 PM
It's quite common & not a massive job to put right, you do get corrosion there, but there's also a lot of stress caused by the rubber mounted front sub frame. I've noticed that Minis fitted with a solid mount kit at an early age still rust a bit, but don't crack like that. My nephew's Mini almost pulled that front section off complete with wings, so we welded it back, fitted a solid mount kit & it never cracked again.
Posted 21 September 2009 - 07:28 PM
Posted 21 September 2009 - 07:46 PM
yes it needs welding and subframe mounting sorted and yes mot fail i fix that area all the time, mainly due to speed bumps and pot holes stressing the mountings a solid top kit and new floor mounts sorts this and improves the handling
dave
