Changing Inner Pot Joint Boot.
Posted 21 September 2009 - 09:50 AM
Posted 21 September 2009 - 10:12 AM
Posted 21 September 2009 - 10:57 AM
Edited by Dan, 21 September 2009 - 10:58 AM.
Posted 21 September 2009 - 11:08 AM
Posted 21 September 2009 - 12:09 PM
Posted 21 September 2009 - 01:34 PM
No, you haven't removed the joint from the shaft. All you've done is break it in half. The star shaped section that the ball cage is pressed over is the inner member of the pot joint. The shaft is pushed into the middle of it. You need to remove the shaft from it in order to replace the boot. Ideally you would never seperate a driveshaft by splitting the pot joint but it seems to have become the norm. It is a bodge though, albeit a minor one.
Hi,
This is what he is talking about.
http://www.theminifo...;hl=stuck joint
Hope it helps,
Ivan
