How Do I Flush Heater Matrix?
Posted 21 September 2009 - 11:16 AM
I have a heater that is only blowing cold air, have read all the posts relating to this and have concluded that i need to flush the matrix - prob is cant find anything that tells me how to do it! Do i disconnect the pipe behind the valve in the engine and stick a hose pipe through that? But what else do i disconnect so the water can flow? Or do i disconnect the pipes going into the heater matrix in the cabin?
Havent seen it before but theres a pipe returning from the cabin which gows directly into the front left side of the head!
Dave
Posted 21 September 2009 - 11:41 AM
Sam
Posted 21 September 2009 - 02:48 PM
Before you disconnect, have you opened the heater valve and then ran the engine without the rad cap on untill water starts the bubble up?
Sam
This will also show if the heater valve is working, which usually fail
Posted 22 September 2009 - 12:43 AM
Posted 23 November 2014 - 07:42 PM
Sam
I'm having a similar issue so I did this and the fluid starts to bubble shortly after starting it up... but my heater hoses are still cool on the inside...
Should I flush the martix?
Posted 23 November 2014 - 07:51 PM
Take a look at this previous thread: http://www.theminifo...ix#entry2974693
Posted 24 November 2014 - 12:43 AM
ok thanks, I'll give that a try. I just wasn't sure what the cap off & bubbling was indicating.
Posted 24 November 2014 - 10:54 AM
Posted 24 November 2014 - 12:50 PM
what i do is
flush the readiator and engine
then do the heater matrix, it made a huge difference to my 1275 sprite
Posted 25 November 2014 - 02:09 PM
Make sure you flush it in the reverse direction he coolant flows.
Which way does it flow? From the heater valve on the head, it is going into the matrix that way, or is that the return?
*edit*
Figured out it is from valve --> matrix.
Edited by crackfoo, 25 November 2014 - 08:22 PM.
Posted 25 November 2014 - 10:58 PM
Posted 27 November 2014 - 07:13 PM
Didn't have time for a flush as it started snowing, but I took off my heater valve and it was clearly clogged. Cleaned it out and hooked it back up and I can feel the hose in the cockpit gets warm now.
