Flowrate Oilpump Hayabusa
2 replies to this topic
#1 De Blerende Beetle
De Blerende Beetle
  • 53 posts
Posted 22 September 2009 - 03:29 PM
Does anybody know how much oil a Hayabusa oilpump pumps at max revs?
#2 Poly_Patje
Poly_Patje
  • 82 posts
Posted 22 September 2009 - 09:59 PM
If you check the Hayabusa manual, you see the following information:
At 3000rpm (oil temp 60 deg.c. of 140 deg.f) it should have a pressure above 200kPa (2.0kgf/cm2, 28psi) and below 500kPa (5.0kg/cm2, 71psi).
For the test procedure, Suzuki wrote down that the engine must warmed up a specific time:
Summer: 10min. at 2000rpm
Winter: 20min at 2000rpm
The oil gallery plug must be tighthened upto 35Nm (25.5lb-ft). (right side on the engine next to oil pressure switch).
#3 De Blerende Beetle
De Blerende Beetle
  • 53 posts
Posted 23 September 2009 - 08:01 AM
Do you also know how many gallons/min or liter/min it pumps?
