1997
The problem is it misfires during acceleration under pressure, it idles ok but when i pull away theres alot of hesitation/misfire, i have replaced labda sensor, manifold airtemperature sensor and the crank case sensor, also the spark plugs and ht leads which are in the right order and the ecu i have had tested. the funny thing is when i disconnct the manifold air temperature sensor the car runs fine, even though it has been replaced as new.
I am a new member to this site and would appreciate some help from all you fellow mini finatics out there.
oh yeh and thanks in advance
Edited by demondope, 24 September 2009 - 05:14 PM.
