After removing the front end i came across a component i have never seen before ( all my previous mins have been older models )
it is a plastic canister with two tubes coming out of the top and through the inner wing ,neither of the two tubes are connected to anything under the bonnet .
Can someone tell me what it is and where the loose tubes should be connected ?
Also should i remove the ECU unit before i do any welding on the shell and are there any other components that should be removed before welding .
Thank You
Maddog
