Year: 1982
Just a quick question;
I got a master and slave cylinder off ebay the other day and went to the scrappy yesterday to get the mounting plate. However while fitting it today, I've found out that the rubber tube coming off the slave cylinder isn't actually long enough to stretch through the hole where it joins the pipe coming from the master cylinder (next to the engine earth) when it is mounted on the plate!?
Were there different types of slave cylinder or has this just got the wrong tube on it? There was a longer tube on the Mini I removed the mounting plate from so I may have to go back and get that unless i'm missing something stupidly obvious
thanks again!
Any non-standard parts that might be involved with the problem?
N/A
